On the road again...
mavada
Re: On the road again...
Post by mavada » Thu Jul 22, 2021 7:26 pm
Shoppinit wrote:
Thu Jul 22, 2021 3:11 pm
It’ll only line up one way when you assemble with the springs and seat. At least that was my experience on the pss9.
Thanks Ben,
Ill see when i re-assemble the lot. :thumbs:
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Thu Jul 22, 2021 7:30 pm
Yeah. Just assemble it and it will probably be obvious what goes where.
mavada
Post by mavada » Fri Jul 23, 2021 9:25 pm
Not ideal on axle stands, but its in....the first... :sleeping_2:
Ive set them (the fronts) 2 turns from softest, i like it firm...max is about 2.4 turns.
The rears set to 1,1 turn from softest, max is about 1,4.
So fronts and rears are set to about 80%.
Forgot to order a wheelnut, almost rounded one when i started.
Yellow Koni's
steve2003rs6
Post by steve2003rs6 » Fri Jul 23, 2021 9:30 pm
Nice one Mav. Hope you have used that copper grease on the pinch bolts ??????????
mavada
Post by mavada » Fri Jul 23, 2021 9:35 pm
:thumbs: Every single f..ing bolt and nut
Yellow Koni's
mavada
Post by mavada » Fri Jul 23, 2021 9:41 pm
Used an old bike tyre inside a wrench to prevent the shafts shock from turning when tightening the shocks topnut and not damage the shaft.
Havent got the special tool to do this.
Yellow Koni's
steve2003rs6
Post by steve2003rs6 » Fri Jul 23, 2021 9:55 pm
Ha ha how did I know you were going to say that.
Because I have been there done that and got the tee shirt.
On quite a few occasions. LOL.
Post by Shoppinit » Fri Jul 23, 2021 10:22 pm
There’s usually a hex socket in the top of the shaft so you can apply counter torque while tightening with a socket spanner.
mavada
Post by mavada » Sat Jul 24, 2021 6:43 am
Yes ,thats the way i got the old one out, which was a 18mm nut
But the nut that comes with the konis (lock nut with plastic lock washer) are 19mm, thats why my socket spanner doesnt fit in the rubber top bearing...
Ive tried to use the old nut but it has a coarser thread.
Yellow Koni's
Mɐʇʇ
Post by Mɐʇʇ » Sun Jul 25, 2021 8:25 am
Hmm. That might be so, by what about your Mrs?
Anyway, bear in mind hard and soft is equally about performance, not fashion. On my Ultima, I run it full soft on the road since the road surfaces are never especially smooth, and then for the track, harder is better.
Running too hard reduces grip, on the road it’s just fashion to have suspension set hard, but it often produces a less balanced handling since the wheels start “skipping”.
You’ve gone way outside of the params the guys on RS6.com tested. Note that I started with their harder settings and then softened them last time I had the car on stands - 1 and 1/2 respectively were too hard. I could feel the car fighting the road rather than conforming to.
Ive set them 2 turns from softest, i like it firm...max is about 2.4 turns.
Mɐʇʇ
Post by Mɐʇʇ » Sun Jul 25, 2021 5:58 pm
Mine on the Konis earlier today waiting to get on a ferry. You can see it sits nice and level. I wouldn’t want it any lower either.
steve2003rs6
Post by steve2003rs6 » Sun Jul 25, 2021 7:19 pm
Matt. You look very young to be driving in the photo.
Surprised your foot can reach the pedals.
Mɐʇʇ
Post by Mɐʇʇ » Sun Jul 25, 2021 7:38 pm
I’m actually a midget.
mavada
Post by mavada » Sun Jul 25, 2021 8:13 pm
No,no, im not the one of the owners with the most firm setting on rs6.com. :thumbs:
Theres one who has al 4 set to most firm... :drink:
Yellow Koni's
mavada
Post by mavada » Sun Jul 25, 2021 9:26 pm
Nice level indeed, do you remember which ride height you choose for the rears, top, mid, or low?
Yellow Koni's
Users browsing this forum: rshales007, S3ADF and 77 guests
