Solenoids in gearbox
philS2
Post by philS2 » Sat Jul 24, 2021 9:55 pm
Does anyone know if it's easy enough to change a valve body on the drive?
I've done my gearbox oil and filter on my drive, so I can get access.
I have several open circuit solenoids, EDS 2, EDS 3, EDS 5 and TSS.
This gearbox has been driving (well sort of) me <beep> mad since 2016.
I've had a "specialist" overhaul the known faults with these and other ZF 5 speeds and it made no difference.
Cheers, Phil.
Re: Solenoids in gearbox
Post by Shoppinit » Sat Jul 24, 2021 10:04 pm
Yeah, I don’t think it’s too troublesome. If you’ve got multiple failures you should consider whether your TCU is knackered.
bilko1
Post by bilko1 » Sat Jul 24, 2021 10:22 pm
Could it possibly be the wiring loom in the box?
Post by Shoppinit » Sat Jul 24, 2021 10:39 pm
Not impossible. Less likely though, I’d have thought.
philS2
Post by philS2 » Sun Jul 25, 2021 11:04 am
Cheers guys.
I've measured them from the tcu connector, then directly on the gearbox plug, and got the same results.
philS2
Post by philS2 » Tue Sep 28, 2021 10:26 am
Update. So I've installed a valve body. (the solenoids had the same resistance figures as my old ones).
The oil was in good condition.
But I've still got 'slipping in second'.
I've decided to get the TCU tested but no one can do it.
I've tried Ecu testing, Bba, Bluehawk, Actronics, Jt Automatics, Control Units and Ecu Tronics.
The problem now (as it has been since 2016) is code 17116 incorrect ratio gear 2.
Has anyone any ideas?
I'm hoping the repair and torque converter replacement in 2018 was done properly.
I know the torque converter code went away afterwards, but still this 17116 remains.
Cheers, Phil.
Post by Shoppinit » Tue Sep 28, 2021 10:50 am
Sounds like the clutches in the boxes are worn then. Or some of the plumbing in the box is leaking.
philS2
Post by philS2 » Tue Sep 28, 2021 12:15 pm
I wondered if it was pressure or clutches.
It'll be staying as it is, if so.
I've had as much as I can take. :boohoo:
Post by Shoppinit » Tue Sep 28, 2021 12:26 pm
Shoppinit wrote:
Mon Dec 23, 2013 9:37 am
It's either an ATF pressure problem (split pipe, cracked valvebody, worn pump, faulty pressure regulator) or a worn clutch pack.
It's possible that the former caused the latter, even in a short amount of time.
Or if the ATF is low then you could get it.
Or if the pick-up pipe is too long causing oil starvation you could get it.
THere's a pipe than can crack that causes loss of pressure. It's accessible by removing the VB IIRC. It looks like this:
Post by Shoppinit » Tue Sep 28, 2021 12:30 pm
philS2
Post by philS2 » Tue Sep 28, 2021 12:33 pm
Nice one. Cheers.
I'll have read through those.
philS2
Post by philS2 » Tue Sep 28, 2021 7:57 pm
Cheers Shopp.
I think I'll get this valve body dropped again and look at that pipe.
philS2
Post by philS2 » Mon Nov 01, 2021 5:17 pm
OMG Shopp. Sure enough, it was that pipe.
Split on the flange.
Looks like that particular one might be under stress from new, as my new one need a bit of adjustment to get the ends in square.
01L 321 475.
Can't thank you enough.
Cheers, Phil.
Post by Shoppinit » Mon Nov 01, 2021 5:22 pm
:thumbs:
ChrisA
Post by ChrisA » Tue Jan 10, 2023 7:15 pm
Just trying to get my bearings, where is the valve body and is it hard to remove?
Users browsing this forum: Majestic-12 [Bot], srichards and 109 guests
