New owner of 2003 RS6 C5 Saloon
- norwichphoto
Re: New owner of 2003 RS6 C5 Saloon
Parking sensors seem to be playing up. Listening carefully to each gives a clicking noise. I get a short low tone and a longer high tone when engaging reverse or pressing the button.
Everyday: 2003 Audi RS6 C5 Saloon in Avus Silver, with black leather upholstery (for sale)
Fun: 1977 Lancia Montecarlo Evoluzione track car. (wife approves)
Wife: RenaultSport Clio RS200
Previously: Toyota Seras (several), TVR Chimaera 400, Mercedes Benz C43 AMG, Toyota Altezza RS200 etc.,
High tone is front sensors, low tone rear sensors. Long beep indicates fault with a sensor IIRC. Vagcom will tell you what and which sensor.
- norwichphoto
Vagcom ordered…
I’m expecting some gremlins after years of inactivity. Climate control panel fan down button and the front left window switch on drivers door panel seems to be malfunctioning. Window switch will operate down but not up.
How do you get the window up?
Uses the one on the LHS door I imagine.
- norwichphoto
Leaned over and used passenger one. New aftermarket switch £10 or so. Guessing it’s a door panel off job?
Can use the auto button to adjust fans to some extent, the panel is cosmetically perfect. Job for the future.
I think you can get the switches out without removing the door card. Pretty sure I replaced mine that way.
- norwichphoto
VCDS arrived this morning.
It found a number of historic error codes, which could have related to low voltage issues when the battery was dead or dying. I've cleared them all and will check back to see how many have come back.
The parking sensor problem has revealed the culprit.
1 Fault Found:
01625 - Front Parking Aid Warning Chime (H22)
31-00 - Open or Short to Ground
New mirror glass ordered from Mirror John, hopefully get that next week.
1 Fault Found:
He has a fast turn-around usually.
Odd fault code to have. Change the chime, I guess.
- norwichphoto
I presume the front one is located in the front of the car. #11 on the attached? Seems to be the same unit front to rear.
- norwichphoto
Update:
Three tanks of fuel in and all seems to be working.
Interior mirror replaced with a new one from MirrorJohn.
Drivers window control switch replaced with a pattern part one from Ebay, new. £ 10 inc postage.
Still need to replace the parking sensor bonger, need to get some radio release keys.
A/C seems to have stopped blowing cold, but the ECON light hasn't come on.
- norwichphoto
So had an ABS / ESP warning light come on today, so ran VAG-COM. Here are the results...
Central locking appears to be working fine.
VIN: WUAZZZ4B63Nxxxxxx License Plate: AO52XAH
Mileage: 47744 Repair Order:
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0002
Coding: 0010752
Shop #: WSC 00000 785 00200
VCID: 6B83CE9FEF981EF34A1-5160
2 Faults Found:
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 00000
VCID: 6393A6BF024856B3F21-51F2
2 Faults Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
00526 - Brake Light Switch (F)
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00001
Shop #: WSC 00000
VCID: 6597B8A70C4C28831C5-2578
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-00 - Faulty
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D37
Coding: 06859
Shop #: WSC 00216
VCID: 343115E3F716810B5BB-4EC8
6 Faults Found:
01561 - Rear left door
59-00 - Can't Unlock
01562 - Rear right door
61-00 - Won't De-Safe
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H08|0805
Coding: 0000030
Shop #: WSC 00000 000 00000
VCID: 2809F1933EDEF5EBE73-5118
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 01146
Shop #: WSC 00000
VCID: 6D87C087D4BC10C3545-5118
1 Fault Found:
Coding: 0010752
2 Faults Found:
Coding: 06697
Shop #: WSC 00000
2 Faults Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
37-00 - Faulty
Coding: 06859
Shop #: WSC 00216
6 Faults Found:
Coding: 0000030
1 Fault Found:
000 - -
Coding: 01146
Shop #: WSC 00000
1 Fault Found:
Probably the brake light switch put the warning light on. Although you could have a vac leak, judging by the SAI code, which could put the light on.
Are you still on the original braided rubber vac hoses?
I’d change the brake light switch. I can’t think of a reason why a DTC would be logged against it unless it was failing or you’d been messing around with it.
- norwichphoto
I suspect I'm on the original vacuum hoses. I've not looked to see where the pipes are and where they go to.
I've just fitted a new brake light switch. GSF had one for £ 8.60, so I'll try that. It was a bit different to the one that came out, but had the same fitting and electrical connector. I have brake lights when I press the pedal, so its doing something...
Lets see if that fixes the fault.
Users browsing this forum: No registered users and 114 guests
