On the road again...
Re: On the road again...
Post by Shoppinit » Fri Jul 09, 2021 1:42 pm
You could get a new nut and thread it on to the end of the bolt, but not all the way, then use a hammer to give a sharp tap on the end of the nut. The nut will protect the end of the bolt. I think wood will be too soft to break the bond.
mavada
Post by mavada » Fri Jul 09, 2021 1:56 pm
Ill try...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
mavada
Post by mavada » Fri Jul 09, 2021 2:28 pm
I smashed the nut i put on in different shapes...not a single movement.
Will try new nut and smash again. Try not to bend the bold i hope...
Yellow Koni's
Post by Shoppinit » Fri Jul 09, 2021 2:37 pm
Try heating one side of the housing with a blow torch. Be very careful to protect the ball joints from the flame.
mavada
Post by mavada » Fri Jul 09, 2021 3:13 pm
Mm i dont have one...
Ill let it soak for a while now.
Ive just turned the steering Wheel to the left, so i have a bit more space to slam it even harder...
Yellow Koni's
mavada
Post by mavada » Fri Jul 09, 2021 8:26 pm
Heres an example of the same nightmare....
https://youtu.be/g7GtQ4tDyj0
Yellow Koni's
mavada
Post by mavada » Fri Jul 09, 2021 9:49 pm
Thinking about it, why not loosen the upper control arms at the top instead of at the pinch bold...?
Yellow Koni's
steve2003rs6
Post by steve2003rs6 » Fri Jul 09, 2021 10:05 pm
Having watched the video. No wonder the garage knackered my hub. And I had to get a new one.
Post by Shoppinit » Fri Jul 09, 2021 10:21 pm
Yeah, that might work. Assuming those bolts aren’t stuck, too.
mavada
Post by mavada » Fri Jul 09, 2021 10:23 pm
:biggrin3:
Not sure how much flex those upper controlarms have when loose from top but still connected to the pinch bold, so the shock can be taken out...?
Yellow Koni's
mavada
Post by mavada » Sat Jul 10, 2021 6:40 am
I would like to know the part number of the pinchbold and nut.
I think it has to be replaced anyway when i go that route...
"What tends to happen is the bolt is slightly bent at the split. So just removing the nut and trying to hammer it out is effective trying to drive a bent bolt through a straight hole. Easiest method is to use a hacksaw and cut the bolt through at the split. Then thread the nut on and as you tighten it , it will pull the now cut threaded piece through. You will have to put washers or a spacer under the nut once you get to the shank of the bolt but it only takes a few tries. Once this is out, you now have a clear shot at punching out the remaining part of the bolt. As the bolt is no longer bent/pinched it will punch out easy, even if it's corroded."
Yellow Koni's
mavada
Post by mavada » Sat Jul 10, 2021 9:09 am
Bold: N  0347908
Nut: N  10272302
Yellow Koni's
Post by Shoppinit » Sat Jul 10, 2021 9:15 am
*bolt
mavada
Post by mavada » Sat Jul 10, 2021 9:16 am
*bolt
:bash:
Yellow Koni's
Post by Shoppinit » Sat Jul 10, 2021 9:33 am
*bald
