Dip stick oil levels
4.2 V8 32v FSI - 444 bhp
Scammo1
Post by Scammo1 » Thu May 27, 2021 12:00 pm
Does anyone know the quantity of oil represented between the min and max marks on the virtual dipstick?
Am guessing about a litre but that is a complete guess!
114uyc
Re: Dip stick oil levels
Post by 114uyc » Sat May 29, 2021 3:40 pm
I think it’s 3/4 of a litre, let Google be your friend
Astonished
Post by Astonished » Fri Jun 04, 2021 1:41 pm
1 litre took it from “just at minimum” to “just full”
But ... the system did say I could put in up to 1.5 litres
That was 3 days ago .. so fresh in my mind
Scammo1
Post by Scammo1 » Sat Jun 05, 2021 8:52 pm
:thumbs:
Rs4nutter
Post by Rs4nutter » Tue Jul 06, 2021 8:35 am
Is there an actual dip stick on these engines? And where/how easy is it to access?
johnnydog
Post by johnnydog » Tue Jul 06, 2021 3:23 pm
I believe there is a dipstick hole situated on the left hand front of the block (obviously! ;) ) - right hand side if looking at the engine. The plastic trim has to be removed to access it, and it is plugged - intended for a workshop manual dipstick check if necessary. Dealers have a dipstick with different capacity markings for different vehicles solely for manual checks.
I only believe this is correct as I watched an RS5 of the same era as the B8 RS4 having its level checked manually at a dealership, so I presume the RS4 is the same.....but will stand corrected of course!
johnnydog
Post by johnnydog » Tue Jul 06, 2021 3:43 pm
I believe this plastic intake has to come off and the access to the dipstick hole is underneath.
Rs4nutter
Post by Rs4nutter » Tue Jul 06, 2021 8:45 pm
Cheers johnnydog, may have a look, if have share day to take trims off!!🤣🤣
johnnydog
Post by johnnydog » Wed Jul 07, 2021 12:25 pm
Assuming that you find the bung for the dipstick hole, don't forget you'll need an actual dipstick of the correct length and level markings. There won't be one in the block.
Rusty Racer
Post by Rusty Racer » Wed Jul 07, 2021 9:35 pm
Sounds like a right faf!
2018 RS4 B9 Carbon Edition
2014 RS4 B8
Rs4nutter
Post by Rs4nutter » Mon Jul 12, 2021 6:57 pm
Found it, got rubber bung on top, couldn’t be bothered to take air inlet cover off 🤷‍♂️
johnnydog
Post by johnnydog » Mon Jul 12, 2021 11:58 pm
Good to confirm at least that the RS4 actually has one as well as the RS5
Users browsing this forum: Google [Bot] and 20 guests
