On the road again...
mavada
Re: On the road again...
Post by mavada » Mon Jun 28, 2021 3:16 pm
Ok, got my crap old VCDS running.
Cleared them after saving.
Here are the codes:
VCDS Version: Beta 912.0
Data version: 20091201
Monday,28,June,2021,15:51:34:60804
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: xxxxxxxxxxxxxxxxxxxxxxx Mileage: 106270km/66033miles
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G01 0002
Coding: 0010752
Shop #: WSC 02195 785 00200
3 Faults Found:
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 002 - Lower Limit Exceeded - Intermittent
16814 - Catalyst System; Bank 2: Efficiency Below Threshold
P0430 - 001 - Upper Limit Exceeded - Intermittent
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
P1127 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT VT1 1315
Coding: 00001
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 00000
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 P
Component: Airbag 8.4EP 2002
Coding: 0000706
Shop #: WSC 00000 785 00200
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 937 B
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 01084
Shop #: WSC 00215
1 Fault Found:
01177 - Engine Control Unit
49-00 - No Communications
End ---------------------------------------------------------------------
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Mon Jun 28, 2021 3:18 pm
See what comes back, if anything.
Post by Shoppinit » Mon Jun 28, 2021 3:22 pm
Take a drive and log your trim values. Group 032 IIRC. See what’s going on. Too rich might be a boost leak or leaky intercooler. Or stuck injector which might sort itself out. If both banks are rich probably the former. If just one, the latter.
Post by Shoppinit » Mon Jun 28, 2021 3:23 pm
Clear your codes again before logging, even if there are none. That will reset your trim to zero.
mavada
Post by mavada » Mon Jun 28, 2021 3:25 pm
Yes, will scan again wednesday after/during some 50km planned.
Dont know if these faults appear again, will do harm during that drive?
Yellow Koni's
Post by Shoppinit » Mon Jun 28, 2021 3:28 pm
Depends if it’s really running too rich. Could poison your cat.
mavada
Post by mavada » Mon Jun 28, 2021 3:53 pm
Thinking about it, the cel came on some 10 km after the MOT.
Could be coincedence , or checked/pulled some hoses...
Will do a visual check tomorrow.
...and maybe no faults come back wednesday...
Yellow Koni's
mavada
Post by mavada » Mon Jun 28, 2021 4:16 pm
For unknown reason the koni 82-2526sport (The rear) arent available ordering here in the Netherlands...
The koni 82-2516sport are.
Yellow Koni's
mavada
Post by mavada » Mon Jun 28, 2021 8:45 pm
Is Virdee still in business?
Yellow Koni's
mavada
Post by mavada » Tue Jun 29, 2021 12:55 pm
I just checked the airbox, there seem to be some play on the drivers site (steering at the left...)part, more as at other side.
Not sure where the mounting points are? Or is it hold in place at the back by the mafs?
Is it possible (if the above is causing the cel...) thats why bank 1 is running too rich?
Yellow Koni's
Post by Shoppinit » Tue Jun 29, 2021 1:10 pm
Check the MAF readings with VCDS. That will tell you if you have incorrect readings.
If there was an air leak so that air was bypassing the MAF I would expect a mixture too lean problem rather than too rich. Still, it's worth checking.
When you press on the back of the airbox then it should be solid. There shouldn't be any springiness in it.
mavada
Post by mavada » Tue Jun 29, 2021 1:21 pm
Thanks Ben.
I noticed the airbox is bolted ok on the right side, but on the left theres nothing it can be bolted to.
By the looks of it, it never has been bolted...
Pic is from the right (and yours methinks)...
Yellow Koni's
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 29, 2021 1:51 pm
There should be a bracket it mounts to on both sides - An M6 Flanged nut along with a rubber bobbin, IIRC.
And then the M8 bolt on top. It seems to be a hobby for garages to only replace the top bolt though.
Post by Shoppinit » Tue Jun 29, 2021 1:59 pm
^This.
The central bolt shouldn't be used to pull the airbox down. If it's not already all the way down, it's not inserted into the MAFs properly.
Such a stupid design.
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 29, 2021 2:05 pm
I also always end up dropping the M6 Nut a few times, they're not easy to get to.
I sometimes wonder how bad the engine bay would have been if Cosworth hadn't done the supposed 100 or so simplifications to make it easier to work on.
At least I eventually realised I don't need to drop the front roll bar or remove the wheels to replace the oil filter.
Users browsing this forum: Majestic-12 [Bot] and 92 guests
