Ohlins Road & Track on my 2020 RS4
Avantgarde
So I bit the bullet and opted for Ohlins Road & Track instead of KW V3 that I usually used on all my previous cars. I ended up using 100N/mm springs in front and 120N/mm springs in the rear, and i must say that the car is just as comfortable as stock but a lot more compliant over rough roads. On the stock suspension the car can be a bit of a handful when driven hard on less than the best roads, but know I laugh at uneven roads.
Some pics for you.
Some pics for you.
Re: Ohlins Road & Track on my 2020 RS4
Sweet!
Did yours have drc or standard dampers?
All black B9 RS4
Avantgarde
simundo777
Lovely! Can i ask what the total cost was on these?
Current: B9 RS4 Navarra Blue
Gone: B8 RS4 Nogaro Edition. BMW 1M. Cayman 981S. E90 M3. E46 M3 CS
Avantgarde
The most accurate figure would be to contact your local Ohlins dealer/retailer.
Is your car a non DRC?
If so, does the stock car tend to be bouncy at times?
So does the Ohlins reduce this bouncy effect? I know that the DFV can be quite comfy than stock.
TIA!
TIA!
2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner intercooler / Radiator| Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm
Avantgarde
Bouncy, no, very hard on rough surfaces, yes. When going fast on rough surfaces my body literally hurts from all the banging, I sometimes feel like I am at the verge of losing control of the vehicle or the steering gets out of my hands. The Ohlins is firmer than stock overall, but much more comfortable on rough surfaces, and I’ve gained back control of my vehicle on high speed rough surfaces.
Did you lower the car height with this setup?Avantgarde wrote: ↑Wed Apr 21, 2021 1:43 amBouncy, no, very hard on rough surfaces, yes. When going fast on rough surfaces my body literally hurts from all the banging, I sometimes feel like I am at the verge of losing control of the vehicle or the steering gets out of my hands. The Ohlins is firmer than stock overall, but much more comfortable on rough surfaces, and I’ve gained back control of my vehicle on high speed rough surfaces.
Can you post some pictures of your car with Ohlins installed?
Thanks~!
Avantgarde
I retained the same ride height as stock.
Thank you for your feedback!
I will look into the Ohlins upgrade down the road!
I just purchased mine, and getting installed as we speak.
Here is how the kit looks like ->
I retained my stock height, and had the car corner weight balance as well.
Avantgarde
Did you run their recommended 120N front and 140N rear springs?
simundo777
Very interested in this kit, any more feedback?
I'd want to retain as much as comfort as possible (even improve it if thats possible).
Are the 100/120 more comfortable than their recommended rates?
Looking at the lic, isn't it lower than stock?
Can you PM me details of dealer and price? I'm in Austraia, and nobody really sells them here.
I've got a modified S5 v8 and a bit sick of the harshness of the KW v3's...
Sent from my SM-G985F using Tapatalk
