Brake pads
Brake pads
Hello, my car 2014 year model 130.000 km mileage, any ideas how often brake pads should be changed, I have ceramic discs by the way.
P.s as I understand it should appear a pad light on a dash board that brake pads should be changed?
Thanks for information
Re: Brake pads
How do they look visually? Is it on its 1st or 2nd set of pads?
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
Re: Brake pads
Looo.... as in in can you see some brake pad friction material or is just the metal backing plate visible when you look at the pad through the wheel, or better still take the wheel off
Re: Brake pads
Look.... as in in can you see some brake pad friction material or is just the metal backing plate visible when you look at the pad through the wheel? or better still take the wheel off
Re: Brake pads
Did some photos of my front pads, don’t know if it makes sense, maybe cleaning car and discs plus pads with huge water steam can solve issues, maybe it’s just a dust, because when I brake gently no squeaking at all
Re: Brake pads
Looks like you still have plenty of 'meat' aka pad material left on them so dont need changing yet. Look like about 50% life yet.
So you get no squeal when driving slow?
Re: Brake pads
Now I got some drive in rain and squeak almost gone I bet it’s a dust or so, need to clean car maybe) thanks for helping)
Re: Brake pads
I would take the wheel of and clean all the vent holes. Done it before and it does help
