Changing a sidelight and DRL bulb turned into one of those 4 letter word inducing three day marathon events, ultimately needing the bumper dropped, light out etc.
In doing so I noticed that I'm missing a few nuts and bolts. Does anyone know of suppliers of these?
I've done some Googling and found *some* of them, but by no means all.
Of particular note on the MIA front:
- the nuts that secure the bumper to the wing...2 on each side, that need an extended socket wrench to get at. M10. They have a cupped bottom so that you can actually undo the nut with a socket. Standard nuts don't work (not easily anyway) as the stud protrudes too far.
- the bolts that hold the bumper on in the engine bay (T30 torx IIRC, with a ready formed washer), 3 of them at the front. One of these sheared off. Have drilled it out and re-tapped, but need a new bolt
I'm also missing a couple of the Dzu type dowel pin twist fittings that go on the underside, and a few plastic twist fittings for the same area. I think I've found packs of these on eBay....
Help gratefully received as don't like having bits missing!
Nuts and bolts
Re: Nuts and bolts
Audi have them all.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Re: Nuts and bolts
Audi part numbers:
Bumper to wing nuts - 4 x WHT001002
Grill to engine bay panel - 3 x N90683305
Mike
Mike
Re: Nuts and bolts
Be careful buying cheap DZU ones for the undertray from ebay. They can be very soft & fail. The Audi ones are expensive but a few quid on them might save the undertray coming loose. A replacement undertray is a few hundred quid!
Re: Nuts and bolts
Completely agree. The ones on EBay are bullshit. If you get them done up, you then later find you can’t undo them. Buy them from Audi, there is a reason you pay more for them.delroyx wrote:Be careful buying cheap DZU ones for the undertray from ebay. They can be very soft & fail. The Audi ones are expensive but a few quid on them might save the undertray coming loose. A replacement undertray is a few hundred quid!
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Re: Nuts and bolts
And there's me thinking £5+ for a nut with washer was expensive
Is there a better parts reference than this:
http://www.oemepc.com/audi/part_single/ ... 525/lang/e
This one doesn't show the nuts with washers as an example, so am a bit sceptical of it.
Users browsing this forum: 666Lenine, Google Adsense [Bot] and 197 guests
