SOLD Audi RS4 B7 Saloon 2006 77k
X555
Post by X555 » Fri Apr 16, 2021 2:43 pm
Audi RS4 B7 Saloon 2006 (56 plate) in Avus Silver - £17,999.
Major jobs done: New clutch, carbon clean, oil cooler and lines, auxiliary radiator, suspension arms, 4x new tyres and more (see below).
Just over 77,000 miles, will rise.
3 previous owners, 2 keys.
MOT until Nov 2021 - no advisories.
Was kept off the road and stored (SORN) for 3 years by the previous owner.
A well looked after and great condition example. Lots of preventative maintenance has been carried out to avoid common RS4 issues.
Maintenance and major work:
  • New clutch and clutch flexi pipe. (30/03/21).
  • Just had Carbon Clean and service. Running 410bhp (see pictures).
  • Recently refurbished wheels.
  • Continental Sport Contact 6 tyres all-round (Nov 2020).
  • Geo setup following new front suspension arms/knuckles and new tyres - Nov 2020.
  • Braided HEL brake lines and Motul RBF660 fluid - Mid 2020 (plenty of life left in the brakes).
  • Gearbox and differential oil replaced with Fuchs Titan.
  • Exhaust centre resonator replaced with x-pipe.
  • Working DRC suspension with no knocks, creaks or leaks.
  • New oil cooler and lines (previous owner).
  • New drivers side auxiliary radiator.
  • All front suspension arms replaced with uprated Meyle HD parts.
  • New front steering knuckles.
  • New wheel bearings and hubs all-round.
I have kept receipts for all work done.
  • Wingbacks with working seat bolsters.
  • Flat bottom sports steering wheel.
  • Carbon fibre interior inlays.
  • BOSE sound system.
Car will be sold with the original LD56 XBJ number plate.
I would love to keep it and had intended to, but I need to get a more practical estate and can't justify keeping this at the moment.
Any questions feel free to ask - 07814578441.
Call me Al...
Now: ...
Previous: Audi RS4 B7, BMW M235i, Merc CLK55.
Dom81
Re: For Sale: Audi RS4 B7 Saloon 2006 77k
Post by Dom81 » Sat Apr 17, 2021 12:28 am
Just a suggestion. Might be useful for potential buyers if you could clear up findings and actions?
viewtopic.php?f=35&t=140943&p=953357#p953357
2007 Daytona RS4 Avant
X555
Post by X555 » Sat Apr 17, 2021 8:25 am
Sure makes sense, I'll expand on that thread now I know more of what happened.
At the very end of the carbon clean procedure, the original garage had unknowingly dropped a bolt from the oil filter bracket down the back of the engine. This happens to be just above a gearbox inspection hole which the bolt fell into. When they first started the car, they noticed a noise from the bell housing area and stopped the car immediately, the car was run for seconds.
Because the original garage were in denial of any wrong doing, I had the car recovered to another reputable garage to investigate and fix as needed. Again, it was not started by my request. Once they removed the gearbox, they found the bolt stuck to the crank position sensor which is magnetic. The sensor was the only part damaged and was replaced with an Audi part. The flywheel had small marks on the outside edge but was not damaged. The rouge bolt was also replaced on the oil filter bracket. No other parts were damaged and there are no cracks or anything like that, if the car was left running or driven it would have been a different story.
As the gearbox was out, I had the clutch kit, flexi pipe, etc changed for new. Annoyingly all the parts looked in perfectly good condition and plenty of life remaining, but it's a big job dropping the box and wasn't going to pass up the opportunity. I sent the pictures (same as in the linked thread) to the original garage who agreed without question it was their error and they paid for the full job, recovery and all.
This means a fresh clutch for the new owner and only a week of stress at my expense. Once the car was rolling again, I took it back only for the post-clean dyno run which you can see now makes ~410bhp.
Hopefully this clarifies things and any other questions I'm more than willing to answer.
Cheers,
Al
Call me Al...
Now: ...
beckford21
Post by beckford21 » Sun Apr 18, 2021 10:19 pm
Regal are useless. Not sure what other specialist you decided to go to afterwards but JKM are really good (based in Portsmouth). I've had issues with Regal with other VAG cars and know lots of people in the VAG scene who have encountered issues. They're not honest and they continue to charge and even make up faults when they can't identify the problem.
Looks like a lovely example. Did it only make 374BHP prior to the carbon clean and then jump up to 410 after? 36BHP is one hell of a jump.
X555
Post by X555 » Sun Apr 18, 2021 10:37 pm
Thanks, and you are right! JKM is exactly who I took it to, they did a brilliant job and fully looked over the car with no issues, even arranged the recovery.
Carbon Clean made a decent improvement, not only power gain, it just runs even sweater now. I had it health checked at Surrey Rolling Road back in January '20 where it made around 380bhp so does line up with Regal's numbers.
Call me Al...
Now: ...
X555
Post by X555 » Mon Apr 19, 2021 10:09 pm
Deposit taken
Call me Al...
Now: ...
X555
Re: DEPOSIT TAKEN Audi RS4 B7 Saloon 2006 77k
Post by X555 » Thu Apr 22, 2021 7:58 am
Sold
Call me Al...
Now: ...
