Sat Nav Problem - can't fix location
rs666
Post by rs666 » Sat Jan 28, 2006 9:04 am
Sat Nav+ can't get a GPS fix on position.
Whilst in the M6 near Stafford last night it thought I was in the middle of the North Sea! (Might as well have been, wouldn't have been going any quicker)
Anyway, anyone else had this problem. I've had a look at the GPS reciever on the roof and there is no visible damage :?
peterb
RE: Sat Nav Problem - can
Post by peterb » Mon Jan 30, 2006 11:30 am
I have experience an occasion when GPS signals were very weak - neither RoadPilot, nor Nav+ could obtain a fix - probably down to atmospheric conditions. However, I was driving between 22.30 and 00.30 on Friday night and had no problem with GPS fixes.
If the problem persists, I would suspect the GPS antenna. Probably the easiest way to prove that would be to extract the Nav+ and attach a separate antenna temporarily.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Nige_RS4
Post by Nige_RS4 » Mon Jan 30, 2006 2:16 pm
My roof mounted GPS antenna failed a couple of years ago (same symptoms). Like Peter says, try another antenna - you will need to allow upto 20mins for it find a signal (preferably whilst you're stationary) I changed mine myself - a new antenna was in the region of £40 from vagparts (is yours roof mounted, as my old one has signs of corrosion on the inside?).
Nige.
craigyb
Post by craigyb » Mon Jan 30, 2006 6:51 pm
My roof mounted antenna was knackered when I bought the car, 2004 RS6, replaced under warranty. Your NAV unit should be able to show you how many sats your receiving.
Craig
rs666
Post by rs666 » Mon Jan 30, 2006 9:00 pm
Says 29 sats available, but none received!
Didn't think there was 29 available at any one time?
Golich
Post by Golich » Sat Feb 11, 2006 7:16 pm
I had similar problem and the whole head unit was replaced. £900! Thank feck it was under warranty!
rs666
Post by rs666 » Sat Feb 11, 2006 8:06 pm
Yep, same outcome.
The head unit is being replaced under warranty...phew!
Nige_RS4
Post by Nige_RS4 » Sat Feb 11, 2006 9:39 pm
The Audi technicians diagnosed my sat nav electronic unit at first, so I got an exchange unit through my warranty company - turned out to be the gps antenna (even though they told me they tried a new one) - I suspect that they didn't allow enough time for the new gps antenna to find it's first fix (it can take upto 20mins for a first fix, possibly even longer) .
I mean £40 versus £900 - I know which I would try first!
Return to “Electrical”
