Hi everyone,
I am trying to find out the recommended oils and fluid information (type and quantities) for a 2014 RS4.
I want to do the final drives and the ATF.
I live in Australia so there may be some slight differences from the UK due to temps but I am unsure.
If anyone can help I would greatly appreciate it.
Apologies if there are already threads for this, I can't seem to find what I'm after.
B8 RS4 ATF & Final Drive Oils/Lubes
Re: B8 RS4 ATF & Final Drive Oils/Lubes
Hi there,OZZYRS4 wrote:Hi everyone,
They are the same fluids over there as in the U.K and the U.S.
I have an RS4 2014 the same as you
ATF DIFF IS : VAG G 055 515 A2 (568ml) Buy 1L
MTF DIFF IS : VAG G O52 145 S2 Buy 1L takes about ( 850ml )
Gearbox ATF is : VAG G 052 529 A2 or Liquid Molly 8100 (7 liters )
Gearbox MTF is : VAG G 055 532 A2 (5 liters)
Hope that helps buddy
Sent from my SM-G920F using Tapatalk
Thanks Steve you legend!
Appreciate your help!
No worries at allOZZYRS4 wrote:Thanks Steve you legend!
