Alternative to 600W rad fan?
Weiß-sechs
Post by Weiß-sechs » Sat Feb 13, 2021 5:55 pm
Part no. 4B3 959 455F, the large rad fan is NLA from Audi as of September last year. Even if it was available the price would be £995 + Vat :shock:
Anyone know of a viable alternative as it sounds like the bearing is shot on mine? It does seem as though it's RS6 specific unfortunately....
Also, can anyone advise on "normal" fan operation? Can't recall the smaller 300W fan ever working; maybe the large one has been doing all the donkey work & worn itself out. Seems like the 600W kicks in when the AC compressor is active so I'm running with the ECON button pressed to try & avoid the fan launching into a low orbit.
Cheers all.
Gregstv
Re: Alternative to 600W rad fan?
Post by Gregstv » Sat Feb 13, 2021 9:47 pm
If you can get it apart you should be able to rebuild it.
Post by Shoppinit » Sat Feb 13, 2021 10:02 pm
It’ll be a PWM signal from the controller so you could probably fabricate something with a similar fan.
Or rebuild like Greg said.
Bowers155
Post by Bowers155 » Sat Feb 13, 2021 11:02 pm
Measure the size of the fan diameter and order after market. Make up some bracket and should be good to go.
As Shop said will be pulse width modulated (on and off duration gives desired speed) so any modern pull style fan “should” work.
srichards
Post by srichards » Sun Feb 14, 2021 10:07 am
Hella make fans. I'd think something of theirs would do. I'm sure I found one of the aircon fans was made by them.
Weiß-sechs
Post by Weiß-sechs » Sun Feb 14, 2021 10:15 am
All good info :thumbs:
At least with this Arctic weather I don't have to worry too much about overheating...
Steve2003rs6
Post by Steve2003rs6 » Mon Feb 15, 2021 4:37 pm
Have you looked on Audi tradition site. Lots of fans for the c5 RS6 in the electrical section.
Came across them today while I was looking for something else.
Classik
Post by Classik » Tue Feb 16, 2021 6:55 am
The part number fits, but not clear by the photo whether this is the 360mm 600w or the 280mm 300w fan. But for the price it's worth asking the vendor for more details:
https://www.kkgkwdm.com/index.php?main_ ... _id=655901
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Weiß-sechs
Post by Weiß-sechs » Wed Feb 17, 2021 2:10 pm
Thanks guys. Some promising info there; I'll delve into the details.
Users browsing this forum: Majestic-12 [Bot] and 74 guests
