B8 brake disc wear indicators?
Hi all, car in at audi atm and been told rear discs are needing changed because the wear indicators show they need changed. Sounds implausible to me, didn’t think the b8 discs had wear indicators??? Thoughts or advice?
2007 RS4 Avus avant - now gone
2013 RS3 black - bye bye
2013 B8 RS4 - Sepang, Ceramics, Buckets, Carbon pack, Sports pack, ACC, B&O, privacy. - now gone
2017 C7 PE - Panther, Ceramics, Carbon pack, BO upgrade.
Re: B8 brake disc wear indicators?
Might be worth challenging audi to what % worn they are and how many miles are safely left. Would think that any warning would be visible to you on the dashboard if they are seriously worn. Keep in mind it's a quick car and these are your brakes though!
yes i would take the Audi centres brake ware with a pinch of salt I've had a few times they tried to get me to change my disks with less the half wear on them as i regularly check the thickness when changing my tyres from winter to summer
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Hi Brooner, know that the new generation discs have recessed holes for wear but wasn’t sure about the b8. Always irritates me when they use “ discs corroded, need changed, worn out “ simple thickness measurement would be a lot more quantitative. Will ask them lol
They do have wear sensors one on passenger side front and one on drivers rear wheel that's unless they have been taken out by someone before you to fit different pads ?CRSRS wrote:Hi all, car in at audi atm and been told rear discs are needing changed because the wear indicators show they need changed. Sounds implausible to me, didn’t think the b8 discs had wear indicators??? Thoughts or advice?
Also be careful as Audi love our cars for the brakes as its an easy cash in for them ask to see via a gauge what mm's are left on them fronts new are 34mm worn out is 32.4 mm but a lot go a little more than that, rears are 22mm new but can't think what the worn limit is of the top of my head 20.8 /21mm ??
Sent from my SM-G920F using Tapatalk
Rear min wear is 20mm.
Agree that it’s best to get them measured as a thickness gauge can’t lie!
Changed mine recently and Audi wanted over £1k. Luckily dealer I bought the car from covered it.
Similar situation happened to me. Took the car to my reliable indie who said disc were fine but the pads needed changing. Definately get a second opinion.
Thanks Steve, know the pads have wear indicators but wasn’t aware the b8 discs did. Front not a problem for me as have the sexy grey ones!!Steve rs4 wrote: ↑Wed Feb 10, 2021 10:46 pmThey do have wear sensors one on passenger side front and one on drivers rear wheel that's unless they have been taken out by someone before you to fit different pads ?CRSRS wrote:Hi all, car in at audi atm and been told rear discs are needing changed because the wear indicators show they need changed. Sounds implausible to me, didn’t think the b8 discs had wear indicators??? Thoughts or advice?
Yeah they want 1100 for them lol.
No worries buddyCRSRS wrote:Thanks Steve, know the pads have wear indicators but wasn’t aware the b8 discs did. Front not a problem for me as have the sexy grey ones!!Steve rs4 wrote: ↑Wed Feb 10, 2021 10:46 pmThey do have wear sensors one on passenger side front and one on drivers rear wheel that's unless they have been taken out by someone before you to fit different pads ?CRSRS wrote:Hi all, car in at audi atm and been told rear discs are needing changed because the wear indicators show they need changed. Sounds implausible to me, didn’t think the b8 discs had wear indicators??? Thoughts or advice?
Very nice indeed
i wish i had the sexy grey ones
lolSent from my SM-G920F using Tapatalk
1100 oh that's cheap bargain ....NOT !!!
Did any other RS model come with the wavy discs?
Seems Audi dropped them pretty quick as new RS4 doesn’t have them
Rusty Racer
Interesting to note these are not handed on the B8, you may notice they run the wrong way on one side.
There was a previous comment that they run at different temperatures - hardly surprising if the fins are running backwards. Even my old 3.2 TT had handed front discs!
2018 RS4 B9 Carbon Edition
2014 RS4 B8
2014 RS4 B8
Ah - I think they are meant to be handed for the exact reason that otherwise the vanes go backwards .
I found a photo of some genuine ones with a direction arrow:
RS4 B8 - Sepang Blue, Black Leather, Aluminium Pack, 20" V-Spokes.
Rusty Racer
The arrows go both ways iirc!!
2014 RS4 B8
2014 RS4 B8
