Hi,
I have an RS4, Emrald Green (only one in the world). Yesterday red exclamation mark plus oil sensor and headlight warning. Dealer says new instrument cluster. I have an oled dsplay I was waiting to replace the streaky one with. Is this the issue or is it really the whole cluster that needs replacing?
Any immediate help gratefully accepted!
SOS help from NZ
Re: SOS help from NZ
You are a lucky guy having one in that colour. I have a serious soft spot for green cars (makes me an outlier I guess) but have never owned one. Got close in 2001 but I digress.
As a fellow kiwi can I suggest contacting Anything Electronic in Nelson as they may be able to repair it? It would be very useful for them to have any stored error codes from the instrument cluster. A scan tool can retrieve these or ask an independent specialist to scan it for you (dealers aren't allowed to give out the codes). In the unlikely event you are in Auckland I'd be happy to do it for free. The clusters are quite straight forward to remove (google that one). If able to repair, Anything Electronic may also be able to change the main LCD screen for you. If they won't do it try Robinson Instruments in Auckland. The screen itself won't be the cause of the warnings.
http://www.anythingelectronic.co.nz/aenz/
https://www.robinsoninstruments.co.nz
- IchBautAuto
Interesting, I replied to this, this morning and it's disappeared! Firstly, check fault codes. Secondly, while clusters are easy to remove they aren't that easy to find so I'd caution on jumping on that solution without being very sure it was a faulty cluster. You mentioned the DIS and replacing that is easy but that wasn't your real question if I read your initial post right.
Can’t help with the issue-soz
But would like to see some pics
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
Gone
F80-M3
B7-RS4
B5-RS4
Users browsing this forum: Google [Bot] and 44 guests
