speed pulse wire colour for tv activation RS4
sg1969
Post by sg1969 » Mon Jan 23, 2006 6:15 pm
HI all
can any of you guys help me turn on tv while car is moving,i think by finding the speed pulse wire into the tv tuner and disconnecting it should do the job,or does anybody on here know where i can have it activated properly
cheers
steven
shineydave
RE: speed pulse wire colour for tv activation RS4
Post by shineydave » Mon Jan 23, 2006 8:06 pm
i bought a small round chrome pushbutton from maplins for about £3 and mounted it under the lower dash panel, you need to cut the wire from the lower 8 pin plug on the back of the sat-nav, it's a thin blue/yellow wire and should be in position 1, you then take both ends of the blue/yellow and conect them to the pushbutton so you can either make or break the gala wire depending on whether you want the tv visable or the sat nav to be more accurate
sg1969
Post by sg1969 » Fri Jan 27, 2006 12:20 pm
thanks for that mate,sounds good i will see if this wire goes to tv tuner also,that would mean that sat nav would be unaffected
shineydave
Post by shineydave » Fri Jan 27, 2006 4:38 pm
the GALA speed pulse wire doesn't turn the tuner off, it merely disables the screen on your nav-plus, you can still listen to the tv channel. the sat-nav should in theory recalculate slower with the absence of the realtime position and speed info from the GALA wire but i've been using it like that for 6 weeks or so with no noticible loss of functionality
Return to “Electrical”
