Well it's interesting about the SatNav and Phatbox, but I'm pretty sure that they are OK. Before I installed that SatNav+ I had the OEM Symphony with BOSE, so my SatNav+ install was a fairly simple swap. The alarm wiring should already be done from the factory.
I've also monitored the Phatbox and am sure it powers itself down. However indeed I am not 100% sure so in one way I'm glad to have the dealer to a current test.
However I actually think I will be wasting my money for the diagnosis. On Tuesday, having driven to Kwik-Fit and then the Audi dealer, the battery was charged up enough to start the engine after each visit. By the time I got home, it should have been more charged (had a short run on the motorway too). I put the car in the garage and disconnected the battery. It had about 12.5 volts o/c, and was only a fraction less before I disconnected it.
This morning I rechecked the o/c voltage. It was now 10.5 volts, and the car wouldn't start. It needed to be jumped again for the dealer to take it away.
So with the battery not holding charge whilst disconnected, it must have a fault. I was almost tempted to cancel the booking and get a new battery, but with all this discussion about if I have a drain or not due to my ICE, I feel better getting it diagnosed. Of course if the result of that diagnosis is that I need a new battery and the electrical system is fine, then I will feel a bit ashamed
