Is there anyway to use the full range of adjustable suspensions? The factory settings for lowering does not go all the way down it seems, on the display in the car there seems to be 3 more levels to go but have not found a setting that enables the last 3 levels (still 3 bars on the graphic) to move down.
Is there a way to lower the car all the way down?
thanks!
How to use the full range of adjustable suspension
mattwez378
It will go to the lowest bar when in RS mode with the suspension set to dynamic
If you have changed no settings RS2 will do it but RS1 won’t, you can modify RS1 to do it though
Re: How to use the full range of adjustable suspension
Yeah the bar thing is a bit weird, as far as I know, you can't fine-tune it, its either up, down or middle!
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Is this on air suspension cars?
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
mattwez378
Jezzer, mine is on air. I believe the DRC suspension doesn’t have the ride height indicator but I may be wrong about that
No indicator in minemattwez378 wrote: ↑Thu Dec 17, 2020 7:46 pmJezzer, mine is on air. I believe the DRC suspension doesn’t have the ride height indicator but I may be wrong about that
Users browsing this forum: Google [Bot] and 47 guests
