MPPS16
Gregstv
MPPS16
Post by Gregstv » Thu Dec 03, 2020 11:14 am
Playing with MPPS16 on windows XP service pack 3. Followed the instructions and can't get the program up. It's says exe running but that is all I get. Any idea of what I am doing wrong?
Re: MPPS16
Post by Shoppinit » Thu Dec 03, 2020 11:16 am
Virtual machine? Or real PC?
Gregstv
Re: MPPS16
Post by Gregstv » Thu Dec 03, 2020 11:54 am
Old laptop. I use it with the William programmer. Had it for 20 years. It's running XP professional with service pack 3.
Re: MPPS16
Post by Shoppinit » Thu Dec 03, 2020 11:59 am
32 or 64bit?
You tried turning off firewalls and AV presumably.
You could try turning off Data Execution Prevention:
https://www.online-tech-tips.com/window ... p-windows/
Could you try running it in a virtual environment with XP SP1 or SP2?
Gregstv
Re: MPPS16
Post by Gregstv » Thu Dec 03, 2020 12:11 pm
I will have a look at this tomorrow. Given up for the night. Early start tomorrow.
Let you know how I go.
Mɐʇʇ
Re: MPPS16
Post by Mɐʇʇ » Thu Dec 03, 2020 11:28 pm
Is this to upload & download tunes on the ECU? I've got both Galletto 1260 and MPPS, I can't remember why, but Galletto was the one that worked for me. Windows 10.
Gregstv
Re: MPPS16
Post by Gregstv » Fri Dec 04, 2020 11:34 am
Want to do a full read of the spare ECU. Once I get that to work I can do the one in the car and make a clone. Well that is the plan.
Mɐʇʇ
Re: MPPS16
Post by Mɐʇʇ » Fri Dec 04, 2020 11:42 am
Galletto did that for me, I think
Gavinda
Re: MPPS16
Post by Gavinda » Sat Dec 05, 2020 5:18 pm
i had the same problem on windows 10 laptop.
apparently its luck to work on xp , win 8 or win 10.
i got fed up of trying , had the program working but still wouldnt connect properly.
loaded it on a windows 7 laptop and works fine.
Gregstv
Re: MPPS16
Post by Gregstv » Sat Dec 05, 2020 8:14 pm
Everything you read says MPPS16 I'd for XP service pack 2. Maybe service pack 3 is playing up with it.
Gregstv
Re: MPPS16
Post by Gregstv » Sun Dec 06, 2020 7:45 am
Found om
ne of the computers with windows 7 on it. I guess you need boot mode to read the files. I am on the desk with the spare computer. Looking at how to make it a clone for the car. I think I need to change the Bosch ID to match the one in the car. I not sure where it is stored yet.
Gavinda
Re: MPPS16
Post by Gavinda » Sun Dec 06, 2020 2:44 pm
you need to copy the immo from your original ecu or do the immo delete on the new ecu then it will work.
Mɐʇʇ
Re: MPPS16
Post by Mɐʇʇ » Sun Dec 06, 2020 11:03 pm
Usually yes if an aftermarket tune, no if stock. And not needed for write usually either, unless the aftermarket tune is a &^%**^&*(
Users browsing this forum: srichards and 258 guests
