Clutch
Re: Clutch
Labour is the big one, mine was £850 in labour but I had master cylinder none which is a 2 hour job itself
Re: Clutch
I was quoted 10 hours labour plus parts.
Ended up doing it all myself, DMF, clutch, slave, uprated pipe, engine mounts & fluid change.
Amazing difference on a 13 year old car
Re: Clutch
I just did a gearbox rebuild, clutch and flywheel. May as well do the fly if doing the clutch. I’ll dig out the costs but for the lot it’s was £2,900ish. £1,500 was the gearbox rebuild.
I supplied the flywheel. No difference in labour costs to do the fly at the same time.
Re: Clutch
Well the new clutch lasted all of 3k miles.... wonderful. So that’ll be about £5k in maintenance this year.
Was hoping it was a master cylinder, nope clutch failure.
I may be falling out of love.....
Re: Clutch
What have camspec said?
Bet you're gutted!
Bet you're gutted!
Re: Clutch
Surely there's some sort of warranty? My only clutch replacement was after 80k or so.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
Re: Clutch
clutch 3k-never
take it back to them
unless its the flywheel and they offered you the choice...?
if they dont play ball get onto trading standards and your bank if paid by card
one thing i would check is the bellhousing bolts,if these have come stack it will feel like clutch failure -happened to me before on a capri 2,8i,clutch wouldnt disengage properly
strangely enough that was after a gearbox rebuild with new clutch too
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 155 guests
