Manually Turning Engine
5.0 V10 50v biturbo - 571 bhp
cammmy
Post by cammmy » Mon Nov 30, 2020 9:08 pm
Something I should have investigated before tearing the car apart. Is there a way to manually turn the engine? I need to make sure the valves are closed before I do the walnut blasting. Maybe an inspection hole in the bell housing that lets me get to the ring gear? Or a pulley somewhere?
The injectors will all be out, so working against compression won't be an issue.
Ta
welwynnick
Re: Manually Turning Engine
Post by welwynnick » Mon Nov 30, 2020 10:28 pm
I usually put a 1/2" socket and ratchet wrench on the pulley bolt.
Nick
cammmy
Post by cammmy » Mon Nov 30, 2020 11:18 pm
Ah cool, thanks. I'd seen a comment about it not being accessible. Do you have to move anything out of the way to get access?
welwynnick
Post by welwynnick » Mon Nov 30, 2020 11:29 pm
Hardly anything's accessible on this engine. You may need to cut a deep socket down to length.
Jim Haseltine
Post by Jim Haseltine » Tue Dec 01, 2020 9:07 am
Yes. The front bumper and the radiators. I doubt that there's any way to get a tool into the pulley with them in place.
I may be thinking about the wrong car but I'm sure that I read something about a special tool that fits in the pulley so the crank bolt doesn't have to be used.
cammmy
Post by cammmy » Tue Dec 01, 2020 10:31 am
Ah crap. So there's no inspection hole in the bell housing that I could use to get to the flex plate?
welwynnick
Post by welwynnick » Tue Dec 01, 2020 10:50 am
You'll find the answer in this thread:
viewtopic.php?f=47&t=129515
There's a small grommet covering an access hole near the bottom, but it might not help you very much.
cammmy
Post by cammmy » Tue Dec 01, 2020 1:46 pm
Cool, thanks. Was hoping for something I could get into and turn from the ring gear. I'll give it a go.
If only it was a manual :-/
cammmy
Post by cammmy » Tue Dec 01, 2020 8:22 pm
So I have an idea, might not be a great one but I'll give it a go.
The crank pulley has little protrusions on it and there's a big boss underneath it. I can get a pry bar in there and slowly lever it around clockwise. I gave it a test and it doesn't take much to move as there's no compression with the injectors out, so I don't think I will damage anything.
Users browsing this forum: hartley1967 and 176 guests
