Gearbox Teardown & Refurbish - 6HP28A61
5.0 V10 50v biturbo - 571 bhp
RS_BROKE
Re: Gearbox Teardown & Refurbish - 6HP28A61
Post by RS_BROKE » Tue Nov 24, 2020 9:15 pm
Front diff
RS_BROKE
Post by RS_BROKE » Tue Nov 24, 2020 9:16 pm
Condition of the front diff
RS_BROKE
Post by RS_BROKE » Wed Nov 25, 2020 6:38 pm
Now I’m really confused 😐
RS_BROKE
Post by RS_BROKE » Wed Nov 25, 2020 7:00 pm
So far the Same but it looks like it is the same gearbox,
Rear output diff
Jim Haseltine
Post by Jim Haseltine » Thu Nov 26, 2020 10:24 am
I'd go by what is on the plate - casting numbers are often inaccurate to say the least. It may well be that the same main casting is used for a number of types of 6HP boxes.
welwynnick
Post by welwynnick » Thu Nov 26, 2020 3:01 pm
I think the answer is that the C6 RS6 'box is both - a hybrid of '26 and'28.
Mechanically it's a 6HP26, and electrically it's a 6HP28.
That's my best explanation for the confusion.
Audi did say at launch that it had an improved TCU with smoother and faster shifts, like the '28.
Nick
RS_BROKE
Post by RS_BROKE » Thu Nov 26, 2020 3:57 pm
Definitely a 28 just the casting it says 26 when I bought it they didn’t check the tag on the bottom because you couldn’t see it was covered by dirt.
RS_BROKE
Post by RS_BROKE » Thu Nov 26, 2020 3:59 pm
Nick
I think this is very early 08 box just on the casting it’s wrong they are all 28 just like the bmw boxes around that time changed from 26 to 28
welwynnick
Post by welwynnick » Thu Nov 26, 2020 4:22 pm
I posted pictures of the '26 and '28 boxes here:
viewtopic.php?f=47&t=129779&start=150#p942033
They're quite different.
RS_BROKE
Post by RS_BROKE » Thu Nov 26, 2020 7:04 pm
This was weird one the bracket for the cooler lines which I thought was torx, then I thought the hole was just filled upon further inspection it’s one of those external torx can’t remember the exact name
RS_BROKE
Post by RS_BROKE » Thu Nov 26, 2020 7:07 pm
That’s not a 26 and 28... a 26 28 look very similar the zf6 family does not look like that that looks like a newer 8 speed out of a c7
welwynnick
Post by welwynnick » Fri Nov 27, 2020 10:00 am
I just checked my photo archive - it's definitely a 28.
It's the 6HP28 and the 8HP that look alike.
Here's another picture of a 6HP28:
And here's a picture of an 8HP65:
The back end of the 28 and the 8HP are also similar, and different to the 26.
Nick
RS_BROKE
Post by RS_BROKE » Fri Nov 27, 2020 9:02 pm
It may well be from the 28 in the B7 3.0 tdi, but none of our c6 gearboxes look like that 28 they alll have different torque converter
RS_BROKE
Post by RS_BROKE » Fri Nov 27, 2020 9:06 pm
This was a bit scary, took all 19 bolts off the transfer case and it wouldn’t budge 116,000 miles all original unopened it was stuck on after slowly working it with rubber mallet it came off but be careful there will be oil still in there and the big metal gasket and the almost circle looking one and the small round one coming off the shaft
welwynnick
Post by welwynnick » Sat Nov 28, 2020 10:26 am
Yup. That's because, mechanically speaking, they're all 26's.
Nick
Users browsing this forum: Google Adsense [Bot] and 160 guests
