The puncture repair can which comes with our cars is a joke and it doesn’t seem like a space saver was even an option when new, so was wondering if the 19inch space saver which was an option for the S4 would fit or if the RS4 stud measurements are unique.
Will an S4 space saver fit?
matthew.lewis2
Re: Will an S4 space saver fit?
The rs4 stud pattern is a pretty generic 5x112 , but it will be the wheel offset that needs to be understood to see if it’s compatible. I’ve never spent any time to understand offsets so I’m afraid I can’t help.
UAE CARS
2009 Toyota Landcruiser - White -4.7 V8 VXR (SOLD)
2014 Mercedes ML500 - 4.7 V8 Twin Turbo (SOLD)
2008 Audi RS4 - Sprint Blue (SOLD)
2002 Range Rover 4.6 V8 HSE (SOLD)
2007 Golf R32 - Black (SOLD)
2005 Lincoln Navigator - White (SOLD)
UK Cars
2015 Landrover Defender 110 Heritage (SOLD)
2014 Audi RS4 - Sepang Blue (STOLEN)
2003 EP3 Civic Type R - K-Pro Remapped (SOLD)
2004 Golf GT TDi 140 - Superchipped to 189bhp (SOLD)
2003 Audi A2 1.4 Tdi
UK Cars
Thanks.
Was also told that the size of the callipers may be a problem.
Might be best to source a spare wheel
matthew.lewis2
19” will definitely fit over standard RS4 steel brakes.
UAE CARS
UK Cars
UK Cars
Having just got my RS4 (this weekend), migrating over from BMW (with runflats) a can of tyre repair seems a bit hit & miss for a high end vehicle?
I looked in the boot when purchasing the car and I recall seeing some bits in / around the battery - so i suppose i should familiarise myself with it all - any tips welcome.
What do you hardened RS owners use? A s/saver seems like a good idea....
Rusty Racer
Last month I got a puncture which triggered the tyre pressure warning system, it correctly identified the punctured tyre too.
There was a hole in the tyre which required a big compressor to re-inflate, the toy one in the boot did not manage it! So I had to take the wheel off and get it repaired as the air was leaking out too quickly. If I was stuck out then I would have used the gunge but have now also suffered a similar issue on my daily driver that required a new tyre I’m thinking the best option is to have something to screw into the hole first (assuming that you can find it of course) as in all my years of motoring I have only ever had nails or screws stick in the tyre not a big hole!
I believe you can get a cork screw type repair for this which snaps off - will need to look for them.
2018 RS4 B9 Carbon Edition
2014 RS4 B8
2014 RS4 B8
Users browsing this forum: Thedarkside and 87 guests
