FYI - I enquired about the Oil Cooler advertised on AMDs site (@340 pounds) - here is their reply:
"The oil cooler kit is from Mocal and we fit them to suit here in our workshop. We use a sandwich plate between the oil filter and housing to carry the oil via a thermostatically controlled valve, to a cooling radiator positioned at the front of the car"
I'm still not too sure what advantage thsi gives
Dunc [img]images/graemlins/s3addict.gif[/img]
Oil Cooler for S3 (from Amd)
Re: Oil Cooler for S3 (from Amd)
basically helps keep engine temperatures down, which inturn means it will perfrm better under extreme loads, such as track days
Can't beat a bit of boost!
Dunk. Wak has had it done. Pics and explanation here...
http://www.wak-tt.com/mods/fmic.htm
ps your have PM in a minute..........
Dunno about anyone else but I noticed quite an increase in Oil temp at Castle Combe.
Usually it's just below 100, on the track it was just over 120 so perhaps an increase of about 25degrees C
I guess the effect was more on the tuned cars.
-Dan
