Feels like it's cutting out???
Asian Panda
Re: Feels like it's cutting out???
Post by Asian Panda » Wed Nov 04, 2020 3:59 pm
Tadass910 wrote:
Wed Nov 04, 2020 2:30 pm
I hope you solve issues mate, good luck
Cheers mate. Will post back after next week when it's looked at.
2016 RS6 C7.5 Sepang Blue
SasaRS6
Post by SasaRS6 » Wed Nov 04, 2020 4:43 pm
We got fingers for you.
2013Audi RS6 C7 Panther Black
2016 Porsche Cayenne Perla White
2016 Range Rover Evogue Black
1998 Buick Century Custom
Use to have:
2013 Audi A8 4.2tdi Black
2008 Range Rover Vogue Black
2009 Range Rover Sport Blue
2013 Mini Countryman SD ALL4 Black
2012 Bmw 530d m package Blue
2009 Bmw X5 3.0d Invidiual Black
Asian Panda
Post by Asian Panda » Wed Nov 04, 2020 6:16 pm
Thanks again :thumbs:
morski
Post by morski » Sat Nov 07, 2020 12:35 pm
There is a known issue with the valve spring on cylinder 5 which usually throws up a dtc in the engine ecu. Audi's first response is to update the ecu and then further mechanical work which involves adding some spring plates on cylinders 5-8.
Other issue is the fuel injector on cyl 5 again you would need to monitor fuel pressure and see if it drops when there is still demand for it. Fuel injector replacement is an engine out job
As yours doesnt have a dtc logged it would need further investigation to check if it is this issue or something else
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
Asian Panda
Post by Asian Panda » Sun Nov 08, 2020 9:17 am
The engine light has now decided to come on, but I won't know what the fault code is until this Saturday when the car goes to get checked....
@morski I'm hoping it's not the latter as that'll be be both expensive and time consuming. I'm hoping for something like a sensor or fuel pump.
But thanks for the heads up.
Asian Panda
Post by Asian Panda » Sun Nov 29, 2020 10:06 am
Quick update.... Fault code given by the engine light as previously mentioned was due to faulty cats. But wait... I don't have any cats as I've straight downpipes hence the engine light.
Coil pack was replaced on cylinder 5 which after testing has proved to alleviate the issue slightly but the car at 5500rpm is now more hesitant than it feeling like its about to cut out.
Guy did say that it only happens under load rather constant which is a good thing???
So back to the guys to see if any of the other coil packs are on there way out.
Asian Panda
Post by Asian Panda » Sun Jan 31, 2021 9:32 am
So I think my saga may be coming to an end... I've recently now replaced all coil packs and plugs and have now removed all mappings so that I'm only running stock ECU and my problem so far appears to have been resolved.
In my opinion, I believe the mapping was the issue as I think it was set up for a higher than safe boost without any further modifications.
But I'm gonna keep an eye on it for the next week and see if it comes back.
Looks like for anyone out there I'd suggest you air on the side of caution with Celtic Tunning maps.
If all goes well I think I'll be going for APR stage 2 map.
Fingers crossed the problem doesn't come back.
crapbag
Post by crapbag » Sun Jan 31, 2021 2:15 pm
Fingers crossed for you dude. Let us know how you get on.
Tadass910
Post by Tadass910 » Sun Jan 31, 2021 3:43 pm
Keep us informed
Users browsing this forum: Google Adsense [Bot] and 69 guests
