rs2 brakes and turbo problems
- stu_sclater
Hi,I've just imported a mint(or so i thought)black rs2 full leather and 70k miles on the clock.The problem is the disc's feel as though they are warped,anyone know where i can get some new ones with out costing me to much.And also there seems to be a problem with the turbo,the boost does not start building till 3500 and only really gets going at about 5000,any ideas on these problems would be greatly apprieciated.Other than that the cars great.Cheers for your help........
RE: rs2 brakes and turbo problems
You can get cheap discs from here if your car has standard brakes.
http://www.eurocarparts.com/
just cant get enough of it
Re: rs2 brakes and turbo problems
You may have a boost leak or you may have a bigger non-original turbo that spools up later.
Do a search for boost leaks on this forum and on www.s2forum.com
Getting brake parts from Porsche or a discount Porsche parts shop such as www.type-911.co.uk or www.design911.co.uk are often cheaper than Audi.
Have a look at this previously posted list of Porsche brake parts that are used (in theory) on a RS2. I did not compile this list so cannot guarantee its accuracy.
Angus
Angus
- Attachments
- Possible Porsche brake parts for RS2.zip
- (10.89 KiB) Downloaded 92 times
RS2 +
RE: Re: rs2 brakes and turbo problems
That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
Re: RE: Re: rs2 brakes and turbo problems
How horrible. Sorry about that, don't know how that happened. I made the zip file from a MS word document as this site wouldn't let me attach a word doc.DavidT wrote:That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
I cant seem to delete the attached file.
Try here instead:
http://www.s2forum.com/forum/showthread.php?t=9177
Sorry.... Angus
RS2 +
RE: Re: RE: Re: rs2 brakes and turbo problems
No worries mate.
I know you didn't do it on purpose but I didn't want you to pass it on either.
David
David
on the turbo issue...i can understand that the turbo starts to kick in on 3000rpm,but then it only kicks in at 22psi around 3700rpm.If it gradually goes up could this mean that i need a turbo service?
i am going to have one with my timing belt change in about 10000km but i was just wondering from the syptoms....
in general are there any symptoms of a turbo service requirement?
- stu_sclater
The file has been cleaned.That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
If you have downloaded it and are unsure that your machine is clean, then try this http://www3.ca.com/securityadvisor/virusinfo/scan.aspx
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
