RS6 - EPC light and traction won't turn off
ASHRAF
Post by ASHRAF » Sun Sep 27, 2020 10:46 pm
Hello and good day everyone,
I've recently bought a used, stage 2 RS6
I've been a huge fan of them but never found the right car until now
So, the car was in the showroom for a while and after I bought it.
The car is a 2015 RS6 with 50k kms on it (in the Gcc countries, it was still pre-facelift)
Issue 1: as soon as I drove off, an EPC light popped up and restricted the revs to 4000 RPM, restarted the car that night and it was fine
Went for a second drive that evening, and after driving it for a little bit it popped back on, then went off on its own without shutting the car down πŸ€”
Speculation: I thought it might've been due to the car sitting for a while, and maybe the battery is weak. So I took it for a long drive and things seem to be normal, will know more in the near future I guess.
Or am I missing something?
Issue 2: the traction does not turn off
I press the button, the traction light does light up on the dash, as soon as I let go, it turns off. Tried holding it for a while and it did not do anything different πŸ˜…
Speculation: diff issue?
I raised the car up, put it in drive, and all 4 tires were turning. I also glanced at the ABS speed sensors visually. Nothing seems to be disconnected or loose, and no wires seemed to be damaged.
I thought I'd ask on the forums to see if anyone faced a similar issue, and would point me in the right direction as to what to do or inspect.
Thank you all
-AJ πŸ‘‹
ASHRAF
Re: RS6 - EPC light and traction won't turn off
Post by ASHRAF » Sun Sep 27, 2020 10:47 pm
Just to clarify, traction does not turn off, even when the EPC light is not on
Daveperc
Post by Daveperc » Mon Sep 28, 2020 9:23 am
IIRC an "EPC light and restricted the revs to 4000 RPM" is a warning that there is an engine management warning - possibly low fuel pressure in one line. You need to get it logged, then clear the codes, and see what comes back.
Possibly if it has been standing a long time it may just need a good run to clear a filter somewhere.
ASHRAF
Post by ASHRAF » Tue Sep 29, 2020 12:03 am
Daveperc wrote: ↑
Thanks Dave,
So took your advice, pulled the codes today, there were many codes, mostly caused by low voltage, the battery needs to be charged up or replaced I guess. Will plug the ctek and see what happens πŸ‘ Also been driving it around so that should help too
There was one code that was saying camshaft position not matching the ECU command or something of that sort. Maybe a sensor? Who knows?
Cleared the codes, ran the car for a bit, floored it, and logged it. The deviation in timing is slight and it didn't through any codes after that. I'll drive it for a short while and see what comes back πŸ˜πŸ‘ just thought I'd update anyone that may have a similar issue
The traction was not turning off due to ABS code stating that the voltage was too low. After driving the car for a while and clearing the code, it can now be turned off πŸ‘
Problem "solved" for now, but I'll update this if any related issues pop up
-AJ
Return to β€œRS6 (C7 Typ 4G) 2013-2018”
