Mɐʇʇ
Re: ££££
Post by Mɐʇʇ » Thu Sep 17, 2020 5:49 pm
Let me have your address and I'll arrange interparcel to come and collect it from you - if you wouldn't mind wrapping it up and chucking a label on it. Is that OK?
Do you want some £ for it and your time?
ChrisA
Re: ££££
Post by ChrisA » Thu Sep 17, 2020 5:59 pm
Great news Steve. 👍😎
Steve2003rs6
Re: ££££
Post by Steve2003rs6 » Thu Sep 17, 2020 6:02 pm
That’s fine Matt. I will let you know when it is parcelled up and ready for collection mate.
I will take it to the workshop tomorrow and use their degreaser cabinet to give it a good clean.
££££££££ Buy me a beer sometime.
IchBautAuto
Re: ££££
Post by IchBautAuto » Thu Sep 17, 2020 11:03 pm
Mɐʇʇ wrote:
Thu Sep 17, 2020 3:43 pm
It’s a stock system.IMVHO all the aftermarket solutions are compromised, either via flow rate or heat management.
It’s stock inlets, sprayed in satin black along with Roose motorsport hoses in cherry red (good match to the RS6 colour), topped off with black mikalor hose clips.
(8 needed cos the don’t make them long enough)
Looks just right. One anal point to consider, the original hoses are accordion, I'm doing the same thing but only securing the hose at the air cleaner end so that any slight movement isn't constrained. I know it's miniscule but the factory ducts are also rubbish and the screw holes to the cross member are already showing signs of tearing.
Steve2003rs6
Re: ££££
Post by Steve2003rs6 » Fri Sep 18, 2020 10:03 am
Matt. Sump all cleaned and boxed up.
Mɐʇʇ
Re: ££££
Post by Mɐʇʇ » Fri Sep 18, 2020 11:07 am
Good man - msg me your name, address & mobile number and box dimensions/weight and I'll get a courier booked to come and pick it up. Any dates/times I should not book it for, or is anything fine?
You sure you don't want some £ for it?
Mɐʇʇ
Re: ££££
Post by Mɐʇʇ » Fri Sep 18, 2020 11:10 am
Yes. The clips aren't very tight and the whole lot can move easily bit enough. I also did the duct screws up first to let the hoses settle into position before nudging the hose clips up a just a little. It's not under any stress, I am sure.
Steve2003rs6
Re: ££££
Post by Steve2003rs6 » Fri Sep 18, 2020 11:16 am
Will do Matt. If you can advise me how to re sync my spare key fob with VCDS. We can call it all square buddy.
Mɐʇʇ
Re: ££££
Post by Mɐʇʇ » Fri Sep 18, 2020 11:34 am
Funnily enough I had recode my fob the other day.
There's lot's of different reported methods, but the only one that's ever worked for me is : http://wiki.ross-tech.com/wiki/index.ph ... Adaptation
Steve2003rs6
Re: ££££
Post by Steve2003rs6 » Fri Sep 18, 2020 11:52 am
Thank you Matt. Will give it a go over the weekend.
Please let me know what label you want attached to the box.
Also just picked up the new windscreen water deflector from AMD. Will get that fitted sometime soon. Black is going to look nice instead of the now grey one lol.
Ps. If poss a days notice would be good for the courier turning up.
Mɐʇʇ
Re: ££££
Post by Mɐʇʇ » Fri Sep 18, 2020 12:23 pm
Is Monday OK?
Steve2003rs6
Re: ££££
Post by Steve2003rs6 » Fri Sep 18, 2020 1:27 pm
Yes mate that’s fine. Have they said approx time ? They will turn up
Mɐʇʇ
Re: ££££
Post by Mɐʇʇ » Fri Sep 18, 2020 1:31 pm
Yeah - just PM'd you. 11:00 to 17:00 is as precise as they offered (parcelforce).
Steve2003rs6
Re: ££££
Post by Steve2003rs6 » Fri Sep 18, 2020 1:51 pm
That’s ok buddy.
Parcel will be ready for them.
Users browsing this forum: Majestic-12 [Bot] and 163 guests
