Hi,
After some fun driving over 5,500 miles I have aquired my first stone chips to the bennets, 2 infact.
Can any one advise what would be best option to considder having bennets painted or repaired any recommedations in the Carlisle area.
Car is just 12 mths old now so hoping not to have painted.
Paul
Stone chip
Re: Stone chip
I use the paint pen that comes with the car
Apply it with with the brush in the pot
Allow to dry for about 10 min then i use t cut with a microfiber cloth with a flat rubber block the keep the cloth from digging out the paint from the chip
Repeat until the chip is full and a final polish with
Maguires ultimate compound to polish any fine scratches
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: Stone chip
Thanks, Did not even know about the Pan, will Check this out.
Paul
Paul
Re: Stone chip
Well not strictly a pen its a touch up pot with a brush similar to a nail varnish brush
Re: Stone chip
Feeling brave and have a dual action polisher?
1. Clean out the chip with alcohol on ear bud
2. Build up paint in layers with applicator / cocktail still until it sits just under level of surrounding paint.
3. Add lacquer so it sits proud of chip
4. Sand carefully with 1800 grit - don't worry if you catch a bit of surrounding lacquer
5. Polish with suitable pad and polish to remove sanding marks
Repair should be almost invisible.
Re: Stone chip
Trust me, the latter sergestion will not happen, you could not let me loose with any Form paint repair.
