light and strong Audi R8 V8
Models: V10 plus, GT, GT Spyder, V8 Limited Edition, Exclusive Selection Edition, China Edition and LMX
4.2 V8 32v Naturally Aspirated - 414 bhp (2007-2011) - 424 bhp (2012-2014)
5.2 V10 40v Naturally Aspirated - 518 bhp (2012-2014) - 542 bhp (Plus 2012-2014) - 562 bhp (LMX 2012-2014)
5.2 V10 40v Naturally Aspirated - 533 bhp (2015-)
5.2 V10 40v Naturally Aspirated - 602 bhp (Plus 2015-)
Speedr8
Re: light and strong Audi R8 V8
Post by Speedr8 » Mon Aug 24, 2020 10:54 am
Hi
The V10 from the 4S R8 has new ignition coils and new ignition plugs.
These can only be better than the old parts.
Tom
Speedr8
Post by Speedr8 » Sat Sep 12, 2020 1:19 pm
Hi
After replacing the wishbones, the question of the wheel load arises in detail.
I think that looks good, slightly higher in the back right and good.
Tom
FaisalJ
Post by FaisalJ » Sat Sep 12, 2020 2:09 pm
1340kg. What weight did it start at?
2007 RS4 B7 Avant
Speedr8
Post by Speedr8 » Sat Sep 12, 2020 2:33 pm
Hi
1640 Kg without driver full tank.
The weight in the picture is with driver and half full tank.
Tom
Speedr8
Post by Speedr8 » Sun Sep 13, 2020 4:10 pm
Hi
There were already flooded engine control units because too much was cleaned with the high-pressure cleaner.
Here is the solution with a rubber seal as a rain gutter for water.
Place shown with red arrow in the picture where the water can penetrate the coupe and the solution in green.
Tom
Speedr8
Post by Speedr8 » Sun Sep 13, 2020 5:36 pm
Hi
And now something that the RS4 B7 drivers might be interested in.
On the R8 V8, the intake valves were switched to a thin shaft from 2010. See picture 1.
The advantage here is that there is less carbon on the valves due to the higher temperature.
The further advantage is a better passage and thus more power.
Audi made the real highlight in the development of the V10 in the 4S, here they have taken a smaller
exhaust valve, which is 1mm smaller and the plug and play with the old V8 and V10 as well as the RS4 B7 V8.
The engines reach their maximum speed in less time, 20% faster than the old V10.
Exhaust valve old 28mm, exhaust valve new 27mm
Awesome, isn't it ?
Tom
mongo
Post by mongo » Wed Sep 16, 2020 11:04 pm
interesting, are you taking the cylinder heads off and getting the valve seats cut/machined to the new exhaust valves? Or are you re-lapping the valves back in?
Speedr8
Post by Speedr8 » Thu Sep 17, 2020 6:11 am
Hi
The new valves have the same seat angle as the installed valves. The new valves, lapping / grinding done.
Tom
Speedr8
Post by Speedr8 » Tue Oct 13, 2020 1:00 pm
Hi
Here is something about air filters made by an automobile club. Unfortunately for you in German, but can be read easily with a translation machine.
It is shocking how bad the foam filters perform in terms of dirt permeability. My finding coincides with this test.
https://www.adac.de/rund-ums-fahrzeug/a ... ortfilter/
Tom
Speedr8
Post by Speedr8 » Tue Dec 01, 2020 11:09 am
Hi
I made the decision to dispose of the air conditioning this winter.
I haven't used the air conditioning for years and thus the weight of the R8 is reduced by 10-12 kg and the loss of
power due to the air conditioning compressor, which is always idling, is eliminated.
Tom
Covkiller
Post by Covkiller » Tue Dec 01, 2020 11:23 am
Oo Tom some things are just worth keeping :biggrin2:
Speedr8
Post by Speedr8 » Mon Dec 21, 2020 5:07 pm
Hi
Removing the air conditioning compressor is too much work.
Remains where he is.
The V8 has parts that can be replaced by lightweight V10 parts.
There are the hoses on the cooling water box, inlet and outlet made of aluminum from the V10.
V10
V10
V8
The surface on the inlet manifold for the TB was also placed vertically, in series the are slightly inclined forward.
Series
New
Tom
Speedr8
Post by Speedr8 » Wed Jan 06, 2021 5:44 pm
Hi
New year and let's go, further modify.
I've heard that filters with a foam cover should be better than series and I'm interested in whether they're better than my big K&N.
The test with a vacuum cleaner was 1 to 1, both of which had a pressure of 0.01 bar generated.
Tom
Speedr8
Post by Speedr8 » Sun Jan 31, 2021 2:34 pm
Hi
Shortly before the start of the season there is a new diffuser.
The old diffuser from 2013 was too aggressive for me and the current one is optically very close to the GT diffuser.
New
old
Tom
Speedr8
Post by Speedr8 » Sun Feb 21, 2021 12:56 pm
Hi
Let's see if this carbon / aluminum anti roll bar can be installed.
3.17 kg is its weight for the front axle.
Tom
Return to “R8 Coupé / Spyder (Typ 42) 2007-”
Users browsing this forum: No registered users and 10 guests
