Pads with least brake dust
Hey all,
After having new OEM pads and discs fitted to the rear I’ve finally had a titfull! The dust is like nothing ever ever experienced before! After 1 week of moderate driving the wheels look bronze! And it’s even stained the tyres!
Thankfully the bodywork, wheels, calipers and disc bells are ceramic coated so they come up easy. But by eck they look unsightly after even one decent journey.
So my question is what pad have people found to be good for reduced dust whilst retaining as good if not better performance. Sadly Performance Friction don’t do the Z-rated pad (that is an incredible pad on the M3)
I’m also going to upgrade the front discs to the 410mm so will do all pads at the same time.
Thanks in advance,
Craig.
Thanks in advance,
Craig.
Re: Pads with least brake dust
I think they must have changed the pad material as mine are awful as well, but the previous set were not this bad.
Yeah my front pads and discs are no where near as bad. I think I’ll send and email over to my parts department and see what they say. As they should be able to see any revisions that have been applied.
- Asian Panda
I believe the greenstuff pads are far less dusty. I just had a new set of brembo OEM replacement pads and there just as bad... So greenstuff will be my next brake upgrade purchase. Better stopping and less dust.
2016 RS6 C7.5 Sepang Blue
Green stuff pads are generally better suited to lighter cars than the RS6.
If you want low dust and something that will actually stop you, Endless MX72 pads would be a good choice for street use. Not cheap but fantastic performance.
Highly rated by Nissan GT-R owners which also suffer from high dust OEM pads.
Misano Red RS4 B7 Avant
Cheers Coffey555 I’ll take a look at them!
- Asian Panda
Never knew about the endless pads. Will have to look into those.coffey555 wrote: ↑Wed Sep 09, 2020 11:28 amGreen stuff pads are generally better suited to lighter cars than the RS6.
Cheers bud
You won’t like them when you find out how much they are
Yeah I’ve priced them up. Approx 630. But I figure I’ll save on wheel cleaner! Haha.
I have read that they are less harsh on the brake rotor so they may work out cost effective in the long run.
Less dust and consistent braking under hard road use is the main draw for me. And far cheaper than a swap to ceramics.
Only one way to find out though. Will report back my findings once I fit a set.
£630 for pads! <beep> that
- Asian Panda
Yea I looked up the price too
Think yellow stuff pads might be a lot cheaper and with similar properties.
