Noise at slow speeds from back tyres
Showyrs6
Post by Showyrs6 » Thu Jul 02, 2020 8:49 pm
Hi
Wanted some suggestions In the recent heatwave with windows down I can hear a really irritating noise from the back wheels. It’s almost like the back wheels have a sticky patch on them.
I have continental tyres all round. I’m inclined to get the rear differential checked out.
Thanks in advance for any input.
Current
2016 RS6 Performance
Previous cars
M140i
M135i
S3
M3
Rx8
Rx7
Honda Prelude
++Few more
Iain
Re: Noise at slow speeds from back tyres
Post by Iain » Fri Jul 03, 2020 9:27 am
Flat spots? I had something similar on a B5 RS4 years ago.
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
Showyrs6
Post by Showyrs6 » Fri Jul 03, 2020 6:40 pm
Yes had a look at the tyres already no obvious flat spots visible.
Seems to be noisy from both sides ie can hear it if I have the window open on the passenger side as well as the drivers side.
Stumped 🤔
Current
Previous cars
M140i
M135i
S3
M3
Rx8
Rx7
Honda Prelude
++Few more
morski
Post by morski » Sun Jul 05, 2020 3:16 pm
Jack up each corner and with the hand brake off spin the wheels by hand to see if they have any flat spots or if you hear any bearing noise
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
zzz
Post by zzz » Sun Jul 05, 2020 3:44 pm
Its not a clicking is it? If so hubs an bearings might need a look (happened to mine)
Showyrs6
Post by Showyrs6 » Sun Jul 05, 2020 10:19 pm
Had the car at Audi for the noise, Came back with usual the tech couldn’t hear it but they recommended rear brake pads and disks needs changing so did that with them but noise still there.
Also checked the wheel bearing definitely not that type of click or tumbling you normally get.
Any other suggestions? I was thinking could it be a noisy diff ? Was thinking of getting Diff and GB oil change done soon.
Current
Previous cars
M140i
M135i
S3
M3
Rx8
Rx7
Honda Prelude
++Few more
Saudirick
Post by Saudirick » Mon Jul 06, 2020 9:04 am
Get the wheels swapped front to back, an easy way to either rule out or prove its the tyres or rims
Showyrs6
Post by Showyrs6 » Mon Jul 06, 2020 11:39 am
Thanks worth a try.
Current
Previous cars
M140i
M135i
S3
M3
Rx8
Rx7
Honda Prelude
++Few more
Hop along scott
Post by Hop along scott » Sat Aug 01, 2020 8:14 am
I have continentals on my c7 Rs6 and notice the noise increased as they wear. My noise goes away when tyres are new. I am swapping to Goodyear soon
Post by MikeFish » Sat Aug 01, 2020 11:10 am
Mine did this first thing in the morning whilst reversing off the drive but at no other times. I put it down to stones caught in the tyres from the gravel driveway.
Showyrs6
Post by Showyrs6 » Sat Aug 01, 2020 10:31 pm
Hi how would you say they sound and is it rear tyres which are noisy?
Current
Previous cars
M140i
M135i
S3
M3
Rx8
Rx7
Honda Prelude
++Few more
Asian Panda
Post by Asian Panda » Sun Aug 02, 2020 9:46 am
Hi all,
I have a similar issue.
I'm getting a drone/ whining noise, starts quiet then progressively gets louder as speed increases (thankfully when it gets to a certain dB it doesn't get louder),
. Doesn't seem like it can be heard from outside as I've drove with the windows down but the noise stayed at the same level as when windows are up. I've recently had pads changed, discs are still good. Swapped all wheels around and tyres have plenty of tread and all running correct psi. I think, it may be coming from front passenger, definitely on passenger side.
Now that I know it's there it's becoming irritating.
HELP!!!
2016 RS6 C7.5 Sepang Blue
sel44x
Post by sel44x » Sat Dec 05, 2020 3:13 pm
Hi All,
I noticed a whining noise at low speeds from the rear of my car also recently and the garage where I took it for service says it maybe from the diff.
I did not realize but there are two diffs on the RS6 2013 as mine is, one is a sports diff and I had an oil change done on one diff but garage did not do
the other one after the service. When I took car back to see about this noise at around 30mph, I was then told about the two diffs and they checked
the oil in the one that had not been done and said it was like treacle and they flushed it through several times.
I still have a noise so its going back next week for another check!
Hope this helps!!
SEL44X :blackrs4:
Tadass910
Post by Tadass910 » Sat Dec 05, 2020 6:48 pm
Update later so we know for future, thanks
Users browsing this forum: Bing [Bot] and 16 guests
