ECU and wiring help please
Human Joist
Post by Human Joist » Sun Jul 26, 2020 5:45 pm
Evening all. I could do with some help identifying which pins in the ecu go to the three knock sensors in our cars please. If anyone has the appropriate image or info.
I’m trying to resolve a knock sensor 3 G198 signal too small - intermittent issue on VCDS. I’ve replaced the knock sensor, which was a pain in the ass. The code is still there so time to look back in to the ecu and also check the resistance on all wires for knock sensors.
Unless anyone else has other suggestions
Mɐʇʇ
Re: ECU and wiring help please
Post by Mɐʇʇ » Mon Jul 27, 2020 8:11 pm
Assume you've checked the ground wire on it already?
(IIRC Knock sensors have 2 pins - 1 to the ECU and 1 to ground)
Human Joist
Post by Human Joist » Mon Jul 27, 2020 9:03 pm
There are 3 to each sensor. And I don’t know which wires are what
Gregstv
Post by Gregstv » Tue Jul 28, 2020 4:42 am
Hope the attachment worked.
Human Joist
Post by Human Joist » Tue Jul 28, 2020 9:45 am
It’s a little blurred but I can make it out. Just got to work out what it all means. Cheers mate
Gregstv
Post by Gregstv » Tue Jul 28, 2020 11:43 am
Send your email and I can send you a clear copy if needed.
Mɐʇʇ
Post by Mɐʇʇ » Tue Jul 28, 2020 12:04 pm
I seem to recall my service guide software (see the linky I think Shopp put in the DIY) has all with wiring diagrams in it
Mɐʇʇ
Post by Mɐʇʇ » Tue Jul 28, 2020 12:08 pm
Plus, google Bosch 3 wire knock sensors and you’ll see some megasquirt guys are using it - so that should give you the pin outs, too
Human Joist
Post by Human Joist » Tue Jul 28, 2020 9:58 pm
Looked and can’t find it.
Human Joist
Post by Human Joist » Tue Jul 28, 2020 10:00 pm
Cheers for your help so far guys. It was a little quiet before so was worried I was on my own 🤣
G198 knock sensor 3 has a wire going to 220 which is a ground in the engine bay.
A shared pin 99 for all sensors
And pin 31 on its own.
Looking at that I’m wondering if pin / wire 31 might be the issue as it’s the only wire on its own. The other two share the same wires as the other knock sensors so would have thought a fault there would trip all three
Mɐʇʇ
Post by Mɐʇʇ » Tue Jul 28, 2020 11:30 pm
Lots of the other sensors will have a choke on them and therefore not be so sensitive to signal noise - but the knock sensor can't.
It is common practice to have sensor earths all go back to the ECU to a common earth there rather than the nearest ground point. Gotta be worth at least banging an ohmmeter on the 2x earths and seeing what you get.
Human Joist
Post by Human Joist » Wed Jul 29, 2020 7:52 pm
Cheers. Will have a look tomorrow as been working
Users browsing this forum: Google [Bot] and 100 guests
