Hi all,
Does anyone know if the 410mm disc upgrade fits behind the OEM 20inch forged wheels?
Thanks in advance,
Craig.
410mm disc behind 20inch forged
Re: 410mm disc behind 20inch forged
Which 410mm disc? With which caliper?
The OEM ceramics that are 420mm fit under the OEM 20s.
Std calliper on BR racing disc.
I dare say the ceramic calliper is lower in profile.
Pretty sure the ceramic calipers are bigger.
A 410mm disc with standard caliper will need a caliper adaptor so can't say for sure if it will fit. If non-one has tried this before then you'll need dimensions from the manufacturer I'd say and check them against the clearance you have.
Yeah that’s the plan for tomorrow. I was hoping my lazy option of that someone had tried it before. I have a sneaky suspicion that they won’t fit. As my smaller Wheel Woolie doesn’t fit between the calliper pins and the barrel.
