Rear Brake discs
Rear Brake discs
Hi, hoping someone can help.
I am trying to source a pair of rear OE Brembo rear discs (new). I don't want to spend the prices Audi are asking for as I have plenty of other bits on the car I need to get done.
Has anyone found any competitive prices? If so how much and where from please. I need to place an order this week.
Many Thanks.
Many Thanks.
Re: Rear Brake discs
Have you tried Reyland Motorsport?h4rvsingh wrote: ↑Wed Jul 08, 2020 11:04 amHi, hoping someone can help.
Many Thanks.
www.reyland.co.uk
B7 RS4 Saloon Mugello Blue, KW V3, Milltek, H&R
Yes Reyland don't do drilled discs to match the front brembos unfortunately.
- GG441
- Location: Wallstrasse 28, Hessen, 35321, Laubach, Germany
Have look at gumtree.
Hope this might help you.
https://www.gumtree.com/car-replacement ... pads+discs
Do pagid do rear drilled discs?
HarpreetSingh
Hi Folks sorry to resurrect the thread, has anyone tried the W12 Phaeton rear discs? Id have through 310mm would clear the carriers because everything else almost matches up with the B7 RS4 spec for the rears. Mine need doing and just thought Id test the waters and see what others thought.
Just look out for pagid on autodoc when they have one of their big discount days if you don't want to pay Audi prices.
https://www.ebay.co.uk/itm/154332438867
I’ve just received one (exactly as described) and will get a right one from autodoc / carparts4less when they have a sale on
WoW !! That is cheaptemo_wil wrote: ↑Tue Feb 23, 2021 9:34 amhttps://www.ebay.co.uk/itm/154332438867
Aren’t oem rear discs pagid anyway and not brembo?
I believe so yes, never seen any rear discs branded Brembo unlike the fronts.
Carparts4less now have stock of the rears, £226 each with the 20% discount code so half the price of main dealers.
Interesting, on t’other side of the pond you can pick up brembo branded rear discs. The pair I bought when I did mine, had all the exact same markings, just not the Audi rings and Audi part numbers.
irn_bru_ce
I bought a set of Giro Disc rotors, Cost about £550, I bought them through Scan Automotive in Vancouver Canada, and collected them while over there for a holiday to avoid postage costs and any hassle with customs. Not that much cheaper initially, but if I ever need to replace them I will only need the outers and will reuse the bells.
https://scanautomotive.com/suppliers/
https://www.girodisc.com/Girodisc-Rear- ... _6338.html
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
