Lifeguard 8 Trans Fluid
5.0 V10 50v biturbo - 571 bhp
IanH755
Re: Lifeguard 8 Trans Fluid
Post by IanH755 » Mon May 25, 2020 1:38 pm
cammmy wrote:
Mon May 25, 2020 1:18 pm
How do we feel about re-using bolts? The old ones came out fine and there's absolutely no way they were stretch bolts, they're barely torqued in all.
If it's the gearbox "sump/oil pan" bolts then thats fine, watched a bunch of GB oil changes and never seen anyone replace them unless they were damaged.
cammmy
Post by cammmy » Mon May 25, 2020 2:31 pm
Nice one, thanks. Yeah, talking about the trans pan. Will re-use.
If anyone needs a service kit for a 28 19 box at a discount, let me know
c3nturi0n
Post by c3nturi0n » Wed May 27, 2020 2:18 pm
Agreed with Ian.
I did my g/b oil change couple times, once to "freshen" the oil in the vehicle as it wasn't done before (made really nice difference regarding gear changes). I then followed up with another one 5k miles later which also smoothen the changes a notch. As I didn't use the suction machine etc. my theory was that with two oil changes 5k miles apart will keep the oil 80-90% clean and good for next 20k miles. In summary, g/b filter, seal, mechatronic sleeve and oil certainly made a difference to my vehicle!
ps. i used genuine ZF L'guard 6 kit... with original Audi supplied bolts :)!
2008 RS6 Avant (Monza Silver)
- H&R ARBs
cammmy
Post by cammmy » Thu May 28, 2020 9:27 am
Nice one, thanks. I'm just waiting on parts now
IanH755
Post by IanH755 » Thu May 28, 2020 10:38 am
Something else to think about regarding the gearbox - Check the engine under tray for the small "air scoops" near the back. these direct air onto the two smaller gearbox oil heat exchangers (house-brick sized) and those scoops can get scraped off/wrecked leaving those coolers to get pretty hot.
Hot GB oil leads to rougher and longer gear changes at full throttle and I found that once I'd replaced my undertray (all my scoops were missing) my gear changes were kept smoother and quicker through-out a spirited drive and the difference was surprisingly noticeable.
Pt No 4f0 863 821 Q (or R) - thats 4F(Zero) not a letter.
welwynnick
Post by welwynnick » Thu May 28, 2020 10:54 am
Those heat exchangers are water-air heat exchangers, one for the gearbox and one for the differentials. The associated water-air heat exchanger is at the front. I think it would be quite important to make sure the thermostat and circulation pump were working properly. I don't know what the scoops are for; there will be a reason, though. I once had a car with air scoops and ducts just to cool the engine mounts.
Nick
IanH755
Post by IanH755 » Thu May 28, 2020 1:56 pm
This is purely my experience, but I posted on here with the timing the difference of gear changes before/after fitting the new undertray because my changes were longer and harsher when the gearbox got hot - after the new undertray the changes were faster and (subjectively) smoother with those air scoops directing cooling air directly onto the coolant/oil heat exchangers and with no other changes.
Whilst I know their are coolant/oil based, rather than air/oil based like the main gearbox radiator at the front, those coolant/oil heat exchangers are also finned (slightly) for air to help with cooling which seemed to be the case for me.
Found it - viewtopic.php?f=47&t=131961&p=914379&hi ... ay#p914379
cammmy
Post by cammmy » Fri May 29, 2020 10:37 am
My undertray is a bit worse for wear, I'll have a close look at the scoops.
The mechatronic seal has arrived at Audi. Will collect today. Is it just a case of unbolting the unit and pulling it down/replacing the seal or is there a procedure to be followed?
cammmy
Post by cammmy » Fri May 29, 2020 2:15 pm
Edit: double post
cammmy
Post by cammmy » Fri May 29, 2020 2:18 pm
Oh, another thing. Do we have the same 4 mechatronic sleeves as the BMW'S? Should I be doing those as well? Is there any reason a BMW HP6 kit wouldn't work? They seem to be more readily available.
https://www.ebay.co.uk/itm/173276483565
cammmy
Post by cammmy » Fri May 29, 2020 2:54 pm
I'm just dumping information here in case anyone else finds it useful in the future.
So my local Audi dealer has a very helpful parts guy. I rang him about the sleeves and he sent me a picture from ETKA and they don't seem to exists on the RS6 box (trans code LLJ) he also said that this trans doesn't appear to have been used in anything else, which doesn't surprise me.
This is a copy of the pic he sent. I can see what look to be the 4 holes that the sleeves wouls be sealing but no sleeves shown
cammmy
Post by cammmy » Fri May 29, 2020 3:42 pm
Potentially useful page
https://www.thectsc.com/images/pdf/6HP26-28_Catalog.pdf
ZF part numberts for the sleeves
0734 317 370
0734 317 371
0734 317 372
Guide sleeve (for sealing the mechatronic harness in the trans casing)
0501 216 272
welwynnick
Post by welwynnick » Fri May 29, 2020 4:38 pm
That doesn't look like the RS6 gearbox, it looks like a 6HP28 as used on some other more recent models, before they switched to the 8HP. The giveaways include the torque convertor attachment disc which is circular rather than triangular-ish, and the NSF drive shaft flange, which sticks out compared with the earlier gearboxes.
I'd be surprised if the RS6 GB didn't have the same seal configuration as BMW's Jags etc, but if it's a 6HP26/28 hybrid, then who knows? The best answer is probably in the fantastic GB rebuild thread by ATinOf.
Nick
cammmy
Post by cammmy » Fri May 29, 2020 5:30 pm
I've taken a punt on the seals at as far as I can tell, they are the same between The 26 28 32 etc.
I'll have a search for that thread
Ta
welwynnick
Post by welwynnick » Fri May 29, 2020 7:26 pm
This is the one in case you were wondering:
viewtopic.php?f=47&t=129779
He did a very good thread on engine removal as well, which I've only read about 42 times so far.....
Users browsing this forum: No registered users and 26 guests
