Coolant leak
Steve2003rs6
Re: Coolant leak
Post by Steve2003rs6 » Mon May 11, 2020 11:06 am
Oh bugger sorry. Then I hope it’s not as complicated as mine is.
I haven’t had a full quote yet. But expecting around 4 to 5 K based on initial estimate from local vag garage.
Fatneck73
Re: Coolant leak
Post by Fatneck73 » Mon May 11, 2020 11:46 am
Where can I find more info re the Buffkin mod?
Steve2003rs6
Re: Coolant leak
Post by Steve2003rs6 » Mon May 11, 2020 12:05 pm
Some info/diagram on this thread re bufkin pipe. The ally mod is the one to go for according to most members recommendations.
Thankfully it can be done with engine in situ.
Although it is still a pain to do.
Fatneck73
Re: Coolant leak
Post by Fatneck73 » Wed May 13, 2020 1:41 pm
Update on mine: o.s.aux rad fubar. QST not had to change these on others so not a common fault for the C6. I’m just special I guess 😁😁😁. Kinda happy - a lot cheaper than the pipes...
Re: Coolant leak
Post by Shoppinit » Wed May 13, 2020 1:42 pm
Aux rad? Is it a Plus then?
Fatneck73
Re: Coolant leak
Post by Fatneck73 » Wed May 13, 2020 1:51 pm
Aux rad yes...so they said. Tisnt a plus.
Re: Coolant leak
Post by Shoppinit » Wed May 13, 2020 1:55 pm
How odd. Only Plusses and cars for hot countries had aux rads. Is yours an import? Or maybe they mean the oil filter / heat exchanger.
Might be a clue in your option codes.
Fatneck73
Re: Coolant leak
Post by Fatneck73 » Wed May 13, 2020 2:07 pm
Ooo dunno. I’ll ask.
Fatneck73
Re: Coolant leak
Post by Fatneck73 » Wed May 13, 2020 2:08 pm
Ahhh... just noted... mines a C6. I searched for ‘coolant leak’... didn’t realise the results were in c5 section. I guess that explains?
Re: Coolant leak
Post by Shoppinit » Wed May 13, 2020 2:24 pm
Haha. Yeah, totally different car. :) I should have realised you had a C6 because your name rang a bell, but I haven't frequented the C6 section for a while.
IchBautAuto
Re: Coolant leak
Post by IchBautAuto » Thu May 14, 2020 12:21 am
Well, I've just joined the club of C5 coolant leaks. Really just a weep. Somewhere I'd picked up the idea that the Australian delivered RS6 didn't have the hot country option but that has proved to be a furphy in my case at least. Hose to pipe weep on the auxiliary radiator system and only when cold. The pipe expands with a bit of heat and seals off. Just happened to be lucky? to see it after stopping after a few Km to get some groceries. As usual, access will be the fun part. Need to remove the headlight to get at the joint. 50times more difficult to get the headlight out than with the allroad, which should be the same but not.
Re: Coolant leak
Post by Shoppinit » Thu May 14, 2020 9:45 am
Easier to remove the bumper and not faff around with difficult access. It's not hard to remove / refit and you'll probably save time overall.
Mɐʇʇ
Re: Coolant leak
Post by Mɐʇʇ » Thu May 14, 2020 10:34 am
Yeah. This ^
simonpoulton
Re: Coolant leak
Post by simonpoulton » Thu May 14, 2020 6:46 pm
Also judging by my lights, quite a big risk off snapping off the lower mounting points doing it without the bumper coming off. I have just made some replacement mounts which seem to have done the trick:
Past: R56 Mini Cooper S
IchBautAuto
Re: Coolant leak
Post by IchBautAuto » Fri May 15, 2020 12:50 am
I've had my headlights out before and the difficult bit for me was the lower bolt with accesses through that tiny hole in the top panel. Otherwise it's a 5 minute job. For some reason the allroad arrangement is different enough to make it a snap, much bigger hole for example, but not here. Dropping the bumper is OK, just so much longer than a headlight out for this specific task.
Users browsing this forum: No registered users and 212 guests
