Michelin Piot Sport 4s - tire tread different
5.0 V10 50v biturbo - 571 bhp
grahamh84
Post by grahamh84 » Tue Apr 28, 2020 1:28 pm
Hi
Anyone else had this trouble ? Just bought a replacement MPS4S tire as I had a manufacturer’s fault In the last couple of weeks and black circles are not stocking MPS4S -(think Covid Michelin shutdown) normally change four tires at a time. Just that I have noticed when the new one has been delivered it has a different channels and they are much wider than the set on the car. I have avoided buying BMW fit and F1. (There is stock every where)
275/35/20 both on the car and one tire replacement
Michelin Product code 276849 - 275/35/20
Plus I’m not sure if you are supposed to change all 4 at the same time due to possibly negative impact grip and car handling?
welwynnick
Re: Michelin Piot Sport 4s - tire tread different
Post by welwynnick » Tue Apr 28, 2020 1:53 pm
They're not quite like brakes, springs or dampers - you can change one at a time if you like.
I'm sure your tyre Shop would LIKE you to change all four at the same, but that's money motivated.
Is your new tyre N1 fit?
Nick
HPsauce
Post by HPsauce » Tue Apr 28, 2020 1:56 pm
Have you checked the sidewall marking to confirm it's definitely the correct tyre?
I just did a Google search on that code and that threw up this ambiguous Costco listing that has pictures of a 4, not 4s and the tread looks like yours…. https://www.costco.co.uk/Tyres-Automoti ... e/p/276849
grahamh84
Post by grahamh84 » Tue Apr 28, 2020 2:06 pm
This one I have also verified with Michelin and Camskill
grahamh84
Post by grahamh84 » Tue Apr 28, 2020 2:17 pm
The gaps a lot bigger
HPsauce
Post by HPsauce » Tue Apr 28, 2020 2:28 pm
Still looks like a 4 tread pattern though, what's on the sidewall, 4 or 4s? And where did you get it?
grahamh84
Post by grahamh84 » Tue Apr 28, 2020 2:32 pm
Definitely MPS4S
Definitely 4s
HPsauce
Post by HPsauce » Tue Apr 28, 2020 2:58 pm
Interesting. I bought one quite recently to replace one with apparent sidewall damage, slightly narrower at 255/35R20.
This is the tread and it pretty much matches the partly-worn rest of the set which are a few years old now (bought at launch in early 2017 IIRC).
HPsauce
Post by HPsauce » Tue Apr 28, 2020 3:06 pm
This is the old one. The damage wasn't as much as first appeared (though the alloy needed expensive work!) so it might find its way back as the spare as that's currently a PSS.
(None in use as the car is still on 18" winter wheels/tyres and probably going nowhere this summer!)
IanH755
Post by IanH755 » Tue Apr 28, 2020 3:07 pm
There is two versions out there -
The design with close tread channel pattern - image is from 2017
Alternative style with wider channels - Image is also from 2017
As to "mix and match" both designs "should" provide the same level of grip etc but looking at how much less rubber would be in contact with the "wide channels" version I can't believe that would be true. I'd contact Michelin and get the definitive answer from them!
HPsauce
Post by HPsauce » Tue Apr 28, 2020 3:10 pm
Mine all seem to be the wider-channel version. Every day's a school day. :thumbs:
HPsauce
Post by HPsauce » Tue Apr 28, 2020 3:15 pm
Definitely MPS4S
They've also changed the logo somewhat since I got mine:
grahamh84
Post by grahamh84 » Tue Apr 28, 2020 3:16 pm
At least not just me then - stuck between having a go at Blackcircles and Amazon who’s sent me the right one.
https://www.amazon.co.uk/gp/aw/d/B01N6S ... prod_image
I am assured these are correct product even if the table is not quite correct. This only stock of standard fitment left - COVID-19 - I’ve request a replacement from amazon see if was mistake or turns up and it’s the same tread pattern
grahamh84
Post by grahamh84 » Tue Apr 28, 2020 3:37 pm
New Tire Dot code 6UB4 00BX 0720
Existing Dot Tire code 4MB4 00GX 1419
HPsauce
Post by HPsauce » Tue Apr 28, 2020 6:07 pm
Mine are:
Old: F3PN 00CX 5016 (made late 2016, bought early 2017)
New: F3PN 00JX 4519
I believe the codes show Manufacturer, plant, mould, batch, year and week.
So I conclude mine were made almost 3 years apart but probably only the batch number and manufacturing date have changed.
They came through a completely different supply route though, the initial ones direct from Europe (Pneus-online) and that latest one from a local tyre chain (Merits).
Users browsing this forum: Jim Haseltine and 22 guests
