Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit - RHD - UK (matte and glossy)
LittleDevil
Trader (Expired)
Post by LittleDevil » Fri Apr 10, 2020 11:03 am
Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit. Fit to all B9 series. A4/S4, A5/S5 Sportbacc, RS5 Sportback and RS4 Avant! Matte and Glossy Carbon Available.
Price: 1150EUR + shipping + paypal fees
Info: PM or litledevil@gmail.com
Audi RS4 Glossy Carbon Interior Trim Kit
Audi RS4 Matte Carbon Interior Trim Kit
bobededog1
Re: Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit - RHD - UK (matte and glossy)
Post by bobededog1 » Thu Apr 16, 2020 1:51 pm
LittleDevil wrote:Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit. Fit to all B9 series. A4/S4, A5/S5 Sportbacc, RS5 Sportback and RS4 Avant! Matte and Glossy Carbon Available.
How easy is it to remove the existing interior trim?
Any pictures Little Devil?
Sent from my SM-N976B using Tapatalk
LittleDevil
Trader (Expired)
Post by LittleDevil » Thu Apr 16, 2020 3:53 pm
It is 1h job or even less. I will make and post some pictures tomorrow.
bobededog1
Post by bobededog1 » Thu Apr 16, 2020 7:49 pm
LittleDevil wrote:It is 1h job or even less. I will make and post some pictures tomorrow.
Thank you
mk280483
Post by mk280483 » Sat Apr 18, 2020 10:27 am
You have also one for lhd?
LittleDevil
Trader (Expired)
Post by LittleDevil » Sat Apr 18, 2020 3:36 pm
Yes LHD is also available, both matte and glossy carbon.
I will post all pictures on Monday or Tuesday.
LittleDevil
Trader (Expired)
Post by LittleDevil » Tue Apr 21, 2020 12:31 pm
Here is picture... RHD matte and glossy carbon, LHD is the same, but I can make pictures too.
LittleDevil
Trader (Expired)
Post by LittleDevil » Wed Apr 22, 2020 12:53 pm
And two more RS4 B9,5 2020 matte carbon, with and without flash.
bobededog1
Post by bobededog1 » Wed Apr 22, 2020 1:03 pm
LittleDevil wrote:And two more, with and without flash.
These look very nice, trouble is they look a like a bit an ordeal to remove existing without causing damage.
Has anyone on here got any experience of removing and fitting trims?
LittleDevil
Trader (Expired)
Post by LittleDevil » Wed Apr 22, 2020 1:54 pm
There is no more than 1 hour to replace all those trims. :wink:
LittleDevil
Trader (Expired)
Post by LittleDevil » Thu Apr 23, 2020 12:53 pm
Here is quick installation guide:
Tools Needed:
- Socket Screwdriver 8mm
- Torx TX20
- Trim Removal Tool
Dashpanel Small Trim:
Remove fuse panel cover on driver side.
Remove 5 screws with Socket Screwdriver 8mm.
Grab your trim where you see the arrow and pull it out gently.
Use Torx TX20 to remove switch and there are 4 clips which needs to te pressed to remove it. Now install you CF frim the same way.
Dashpanel Long Trim:
3 x Torx TX20 screws needs to be removed. Open glove box and remove then and one on the other side.
Once all 3 screws are remove you just need to pull trim out. Start on passenger side you can us trim removal took or simpy grab it and gently pull it out.
You need to remove AC unit and mileage reset switch. There are 4 x Torx screws on AC unit and numbers of tabs and two tabs on mileage reset switch. Now install you CF frim the same way.
Center Console:
Remove 1 x Torx TX20 screw on the bottom of stowage compartment under rubber...
Use trim removal tool and pull it out on one side and than on the other.
Remove two Torx TX20 screws to remove stowage compartment. Now install you CF frim the same way.
Door trims:
Only trim removal tool is needed for all 4 door. Gentyl access to the tabs behing with removal tool and that's it.
If you have any question feel free to ask. :thumbs:
Ales
LittleDevil
Trader (Expired)
Post by LittleDevil » Tue May 05, 2020 3:29 pm
2 x Matte Carbon and 2 x Glossy Carbon available for RHD - UK Cars.
Kind Regards
LittleDevil
Trader (Expired)
Post by LittleDevil » Mon May 11, 2020 8:32 am
Picture from customer, took him 45min for installation...
LittleDevil
Trader (Expired)
Post by LittleDevil » Wed Sep 02, 2020 6:39 pm
More sets vailable for RS4 and RS5.
Best Regards
LittleDevil
Trader (Expired)
Post by LittleDevil » Wed Sep 02, 2020 6:46 pm
RS5 Coupe - Glossy Carbon
Users browsing this forum: Google [Bot] and 19 guests
