My outside temp is showing apx 3 Celcius to much at any given time. I have compared to the A6 that shows more or less correct.
Changed the sensor without any luck.
Can these be calibrated/adjusted in more or less them same ways as the tank gauge via VCDS?
Outside temp sensor - Possible to calibrate?
2003 RS6
2000 S8
1993 URS4
2000 S8
1993 URS4
Re: Outside temp sensor - Possible to calibrate?
The outside air temp has always been total fantasy. I don't know how they got it so wrong on the RS6.
This is something that bugged me when I first got the car and I don't remember finding a way to adjust it with the Vagcom. I'm pretty sure there is no way to calibrate it with the Vagcom. I haven't looked for years, though.
Presumably it's a thermocouple type sensor. You could try putting a potentiometer in parallel with the sensor to see if you can make an offset. Not sure how that would affect linearity, though.
I seem to remember the issue with the sensor being one of location. You could try putting it somewhere where it's less sensitive to heat soak from the engine.
Some reading for you:
viewtopic.php?f=2&t=105312&p=616976
viewtopic.php?f=2&t=87598&p=413903
viewtopic.php?f=2&t=76022&p=308735
Users browsing this forum: No registered users and 252 guests
