Radiator Fan does not stop running
Over the last couple of days, after an easy drive back home from work I realise once I shut the engine off, the radiator fan will still run for a couple of minutes before shutting off on its own? Anyone has a similar experience?
Re: Radiator Fan does not stop running
Mine always does that maybe for a minute after I switch the ignition off, I assumed it was normal
2019 Ara Blue RS3
Previous:
2014 Riviera Blue RS4
2006 Sprint Blue RS4
Previous:
I noticed that last week (not driven since I have been in forced isolation) for the first time. Could just be where it is a few degrees warmer.
2013 B8 RS4 - Reflex Silver Black Pack probably the 2nd lowest mileage in County
2014 B8 RS4 - Daytona Grey bag of nails with Silver Styling gone
The newer ones all do that as the turbos are now in the middle of the engines,so run warmer.
Sent from my SM-G973F using Tapatalk
Rusty Racer
Mine does that and sometimes it stops and then starts up again. Can’t say I’ve ever been worried
2018 RS4 B9 Carbon Edition
2014 RS4 B8
2014 RS4 B8
Exactly the same as thisRusty Racer wrote: ↑Sun Mar 29, 2020 6:34 pmMine does that and sometimes it stops and then starts up again. Can’t say I’ve ever been worried
2019 Ara Blue RS3
Previous:
Previous:
I had the same issue as you mentioned with the radiator fan still running after a drive,that was away back at Christmas and when it did this I noticed it was unusual as it had never done it before.
Then come mid February while driving about 10miles from home a message came up on the dash saying not to exceed 6000rpm.
Then water temp increased as well as the oil temp.
To cut a long story short, it ended up being the thermostat causing the issue, I also got the water pump replaced also at the same time as the stat, no problems now and no radiator fan running after car switched off.
This may be the start of the same issue that turned out for me.
I hope not as had the Stat replaced last year.SteffRS4 wrote: ↑Tue Mar 31, 2020 1:27 pmI had the same issue as you mentioned with the radiator fan still running after a drive,that was away back at Christmas and when it did this I noticed it was unusual as it had never done it before.
The above was exactly what happened to me, motorway speeds or spirited driving it would be fine. A or B Roads (especially following) it was heat up.
Hi G30001
Yea unfortunately that was the issue regarding mines.
Motorway driving at Christmas is when I noticed the fan staying on after switch off.
I mentioned it in another section on here and it was yourself that replied bud.
Anyway all fixed now, and since it has I’m lucky if I’ve driven 50miles since.
It’s never been as clean now due to this lock down
m_coupe1999
Same here! Lately i am always noticing the fan noise! Loud and on almost all the time. I feel like the fan is over working itself! And one of u mentioned a warning fault "not to reach 6000 rpm", i got that too for 2 mins then it went a way!
I wonder what the problem is and if the fan and that fault are connected?!
2014 Audi Rs4 Avant
2017 Audi R8 V10 Plus
2010 Porsche 997.2 Turbo
2014 BMW M6 GranCoupe
Get it scanned when you can, sound exactly like mine which was thermostat sticking.m_coupe1999 wrote: ↑Thu Apr 02, 2020 11:28 pmSame here! Lately i am always noticing the fan noise! Loud and on almost all the time. I feel like the fan is over working itself! And one of u mentioned a warning fault "not to reach 6000 rpm", i got that too for 2 mins then it went a way!
m_coupe1999
Just got a call from Audi, its a thermostat problem; needs replacement.
2014 Audi Rs4 Avant
Seems quite a common Audi fault, mother in law and pals A3 have also had them.
