ABS fault
Gregstv
ABS fault
Post by Gregstv » Wed Feb 26, 2020 9:21 am
Hi Guys,
Good weather today so I took the RS6 to work. Stopped on the way home for some fuel. When leaving the servo the ABS light came on and the ! symbol as well as MIL and a long beep.
Code is as follows,
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Control Module Part Number: 4B0 614 517 AD
Component and/or Version: ESP 5.7 RS 6 2310
Software Coding: 06697
Work Shop Code: WSC 02195
VCID: 6393530E724BDA6FB45-51F2
1 Fault Found:
00301 - ABS Return Flow Pump (V39)
35-00 - -
If I clear the code it wont come back on until the car gets moving again. Would a ABS wheel sensor set this off? Any ideas? I have checked the ABS fuse and the wires to the ABS module.
I will try and log the flow pump with VCDS tomorrow once the battery in the laptop is charged.
Thanks,
Greg.
ahoooga
Re: ABS fault
Post by ahoooga » Wed Feb 26, 2020 8:53 pm
Could possibly be the abs controller itself. I went down the 'change the abs sensor' route last year,( given my VCDS log) only to do 40 miles and got the same errors again.
Your VCDS log does read slightly different to mine ( before i changed the wheel sensor though)
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 00000
VCID: 63CF9773F19E2A3913D-5140
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-10 - Open or Short to Plus - Intermittent
Gregstv
Re: ABS fault
Post by Gregstv » Sat Mar 07, 2020 10:29 pm
Found a guy locally selling RS6 parts. Went to have a look for the ABS module. There was a whole RS6 in peace's. A damaged motor and a replacement motor. The car had a front end crash. The transmission was sold but it looks like the rest of the car is there. Interior was all pulled out an in boxes. The engine bay was fully stripped. Front damage has been repaired. The more I looked the more parts I wanted. Ended up buying the whole car. Came with new tyres, Wagner's, KW,s and near new brakes and 2 motors. Front rotors are 390mm. I think there off a C6 RS6. Lots to go through. Haven't found the ABS module yet. Running out of space to store everything with more still to pick up.
Gregstv
Re: ABS fault
Post by Gregstv » Sun Mar 08, 2020 6:09 am
ABS is fixed I hope. Found corrosion inside the main connector on the ground pins and the 2 can pins. Cleaned them up and coated with CRC 226. Took for a good drive and no ABS light. Now to put the big brakes on her.
IchBautAuto
Re: ABS fault
Post by IchBautAuto » Sun Mar 08, 2020 9:49 am
Absolute bonzer find. The auto box would have been a bonus but otherwise plenty to play with. I'll drop by and offer some useless suggestions about where to put the bits.
Great news about the corrosion in the connector. Hope that's it.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 516 guests
