Exhaust valves problem - SOLVED !!
jipettersen
Post by jipettersen » Mon Aug 07, 2017 3:59 pm
Anyone of you experienced (as i) one of the valves continuous open? Will not close in "Comfort" mode.
dasquade
Re: Exhaust valves problem
Post by dasquade » Mon Aug 07, 2017 8:29 pm
I used to have it when i swapped from stock exhaust to milltek. The left one (drivers) side wouldn't open. I couldn't figuer it out, so untill i found out why i had loosen up the actuator, manually turned open and soft bolted it back on. Drove a half year around with it untill i recently decided to check again. Realigned the spring and valueplate...and what you know, it was correct now.
*since then i installed a CETE value controle module. I can now independant of drive mode controle the values if needed (you can bypass it and stays), but you can activate it to behave in all modes aswell).
Not a help really, but yes i had it also and somehow self corrected itself :s.
jipettersen
Post by jipettersen » Mon Aug 07, 2017 10:15 pm
Thanks ! For me its OPEN all the time.
I also have Milltek and the valve control module from MTM working in more or less the same way as you describe.
Visited the Audi dealer today to check for errors with their AUDI Diagnose system but there was none! They disconnected the Valve controller to see if helped but it didnt. So they booked me up for a new appointment next week to take a closer look. They state it could be the electro motor actuating the valve. If not it could be in the ECU?????
Story is , when brand new car in jan 17 the dealer installed this MTM valve controle module and i was a little disappointed since there was very little change in sound level open/closed.
Next in feb i had MTM tuning of the engine at a MTM dealer. Before tuning they used Vag Com to check for any errors in the car. There was just one error showing "exhaust valves" or something set the date the valve unit was installed. They did a reset and there was a significant difference in sound level. This tells me only one valve had been working until that point .
After reset it was working seamlessly until last friday i picked the car up after a left front brake disk replacement at Audi.
Strange.
jipettersen
Post by jipettersen » Tue Aug 08, 2017 1:39 pm
Problem solved by myself. The spring connection from the exhaust valve motor and the valve itself was "out of position".
Rugman
Re: Exhaust valves problem - SOLVED !!
Post by Rugman » Tue Aug 08, 2017 7:17 pm
They replaced ONE front brake disc ???
dasquade
Post by dasquade » Tue Aug 08, 2017 7:26 pm
Nice you got it sorted, guess it was a bit what i had. Anyway ;).
jipettersen
Post by jipettersen » Tue Aug 08, 2017 8:43 pm
Yes just left front ! The others was OK.
Audi claim it must be a rapid cooling like cold water on a very hot disk. Warranty refused but covered by the sales dep.
Dont like this and never happen before on any of my cars.
Tadass910
Post by Tadass910 » Thu Aug 10, 2017 10:18 pm
Strange, using Miltek and it always closes in comfort mode
jipettersen
Post by jipettersen » Sat Aug 12, 2017 9:07 pm
Yes thats correct behavior regardless of Milltek or not. And when you stop the car in COMFORT valves open for next run.
But as i stated in post over, the spring connected to valves and motor was out of position. Easy fix.
Tadass910
Post by Tadass910 » Wed Aug 16, 2017 2:31 pm
You mean in comfort shut engine? When you shut engine in comfort valves stay open, when you start car in comfort valves closed automatically
jipettersen
Post by jipettersen » Fri Aug 18, 2017 8:38 am
I mean. When i shut down the engine in COMFORT mode and then look at the valves they are fully open.
Then when you start the car again in COMFORT mode the valves are open but close again after a few seconds (warm engine in Comfort)
Tadass910
Post by Tadass910 » Fri Aug 18, 2017 2:32 pm
So it's normal
Mykoh
Post by Mykoh » Sat Feb 08, 2020 4:29 pm
I’ve been having this exact issue. I know it’s an old post but I’ve got a 2015 s7 with apr exhaust. The Shop ended up swapping actuators bc the driver side kept staying closed. We unplugged them as per your post and just going to give it some time and plug them back in later.
We shall see lol.
In regards to OP. We tried to swap and realign the actuators and nothing was working right. Leaving them open all the time isn’t ideal bc it’s got a lot more droning now but 🤷🏻‍♂️
Idk if you’ve got any other ideas
dasquade
Post by dasquade » Sat Feb 08, 2020 5:05 pm
Not sure what valves APR use but milltek used valves with additional little spring under the valve (i suppose against rattling flap or give it some extra tension). But over time exhaust carbon fills up the cilinder with spring and therefor the OEM spring can't push the valve downwards enough and valve keeps in lock position (small lip).
SInce i removed the little spring on both sides, they been working flowless in combination with the cete exhaust module (manual overwrite + memory).
Tadass910
Post by Tadass910 » Mon Feb 10, 2020 11:57 am
Sometimes wd40 solves issues
