intercooler options?
Mɐʇʇ
Re: intercooler options?
Post by Mɐʇʇ » Tue Feb 04, 2020 1:46 pm
I have the wagner coolers, their shrouds and their hoses. I didn't use the wagner grille though, although I do have it. I remained stock.
* The coolers are nice.
* The shrouds are fairly flimsy, but fit OK, although It was a bit tricky attaching them (I have the old ones saved as backup)
* The hoses aren't great. I recommend https://www.ebay.co.uk/itm/252828100894, but ask them to leave the NS lower hose oversize and trim it to length yourself.
Jayjay101
Post by Jayjay101 » Tue Feb 04, 2020 9:36 pm
I’ve got kwe’s on mine and there really well made and twice the size of oem ones.really good value for money in my eyes
Jayjay101
Post by Jayjay101 » Tue Feb 04, 2020 9:47 pm
Jayjay101
Mɐʇʇ
Post by Mɐʇʇ » Tue Feb 04, 2020 10:07 pm
Roose Motorsport (Paul Roose) FTW
They really are top quality hoses.
Jayjay101
Post by Jayjay101 » Tue Feb 04, 2020 10:26 pm
Mɐʇʇ wrote:Roose Motorsport (Paul Roose) FTW
Worth every penny mate!
Ajc
Post by Ajc » Tue Feb 04, 2020 10:36 pm
I’m impressed that there’s not a single pair of wire cutters in any of those pics jay . You learned your lesson 😂 loving the meth too 👌
Cheers Al
Jayjay101
Post by Jayjay101 » Tue Feb 04, 2020 11:22 pm
Ajc wrote:I’m impressed that there’s not a single pair of wire cutters in any of those pics jay . You learned your lesson Image loving the meth too Image
That was an expensive mistakeImageImage
GreggPDX
Post by GreggPDX » Fri Feb 07, 2020 8:03 pm
I went through a similar analysis and landed on the Wagners. It may be possible to get comparable results cheaper by going custom re-cores, but the in the savings was not worth the potential hassle.
Regarding the CF shrouds, they are definitely a struggle to fit. If you look at the stock shrouds, they are hard plastic with little rubber flaps on the front to seal against the bumper cover. There are various hoses and brackets that the shrouds have to fit around, and the rubber provides flexibility. The CF shrouds technically fit the same, but there is almost zero flexibility, so getting them to line up while manhandling the bumper cover back on is a pretty huge PITA. I ended up dremmeling away some small sections on the front of the shrouds to get them to fit smoothly. In the end, they worked OK, but took a lot of trial-and error to get a good fit. Also, the provided method for attaching them to the intercoolers themselves is <beep>, so I modified IT to work better. When the bumper is fitted, the shrouds are wedged in good against the intercoolers anyways, so the mounting screws really just to hold them while fitting everything up.
IchBautAuto
Post by IchBautAuto » Sat Feb 08, 2020 1:20 am
I reinforced the shroud edges with aluminum and 3M tape. The screws tear the CF over time otherwise.
Mɐʇʇ
Post by Mɐʇʇ » Sun Feb 09, 2020 7:44 pm
My CF shrouds are actually cable tied on for these ^^ reasons.
Worked well enough.
Classik
Post by Classik » Thu Feb 13, 2020 10:01 pm
The bottom silicon hoses provided with the Wagner kit keep on popping out, turbo side, not Intercooler side. Might try one of the suggestions above ^^, particularly the oversized option..
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Classik
Post by Classik » Sat Feb 15, 2020 7:14 am
What are those custom AEM stuff on the side? Pressure sensors?
Jayjay101
Post by Jayjay101 » Sat Feb 15, 2020 7:50 am
That’s a methanol injection nozzle mate
Classik
Post by Classik » Sat Feb 15, 2020 8:05 am
Wicked :FIREdevil:
What kind of figures can you get with this stuff? (and does your gearbox like the mod?)
Users browsing this forum: asgor, srichards and 100 guests
