Blow off valves
5.0 V10 50v biturbo - 571 bhp
dilyanyordanov
Blow off valves
Post by dilyanyordanov » Sun Jan 19, 2020 10:30 am
Hi guys,
I wanted to purchase blow off valves when my milltek catback was installed but the Shop contacted forge and they said that there are 3 sizes and they are not sure which one fites rs6 c6...which is kind of funny buy anyways...Does anyone know what size fits ? I believe it was either 34mm, 36 mm or 32mm maybe...Thanks
IanH755
Re: Blow off valves
Post by IanH755 » Sun Jan 19, 2020 12:27 pm
The RS6 blow-off valves are molded-in to the lower half of the plastic airbox so there is no ability for a direct swap to Forge etc. Instead you have to cut out the plastic OEM ones, buy the aftermarket ones and glue them into the holes left in the plastic airbox by the cut-out OEM ones.
It's been done by a few people on here before and at least one has taken photos of what they did - their thread with pictures is here - viewtopic.php?f=47&t=128908
RS6-T28RPH
Re: Blow off valves
Post by RS6-T28RPH » Sun Jan 26, 2020 3:31 pm
These are the ones I have fitted to mine (obviously make sure you buy a pair!) : https://www.forgemotorsport.co.uk/Turbo ... --756.html
20k miles on and still no issues, had a play with swapping the springs out, seem to have found a happy medium with the blue spring with MRC Stage 2 tune (https://www.forgemotorsport.co.uk/Valve ... --826.html) and gives a nice modest whoosh back into the airbox when backing off full boost, nothing crazy like a scoobaru or and jap thingy but a nice noise, just to let everyone else know you have backed off :-)
Esben Business IT Solutions - http://www.esben.co.uk
Esben Remapping - http://remap.esben.co.uk
2015 BMW X6 M50d (wife-transport, not allowed to touch :cry: )
2008 RS6 Avant Phantom Black - MRC Stage2 (ecu, tcu & 2nd cat bypass) 730 PS/1017 nm
2006 BMW 535d Pre-LCI - Stage 1 (340bhp)
2003 VW Polo 1.4Tdi (3pot shitbox) tuning project, was 73bhp, now 120bhp, aiming for 160bhp before it goes bang! (put in the bin)
Per_S
Re: Blow off valves
Post by Per_S » Tue Jan 28, 2020 10:40 pm
You can use these as well. https://www.gfbuk.com/product.details.c ... uctid=1027
No springs to swap in them.
dilyanyordanov
Re: Blow off valves
Post by dilyanyordanov » Sat Feb 01, 2020 5:11 pm
Thanks a lot for the help guys. When does one actually need aftermarket bov if mine haven't failed yet. I am at 773 hp and 1039nm. Stock turbos ...
IanH755
Re: Blow off valves
Post by IanH755 » Sat Feb 01, 2020 5:28 pm
When the boost pressure you are running exceeds the amount the OEM valves can cope with, usually if you increase the boost on the OEM turbos or buy new turbos running higher boost, or alternatively just because you fancy something more user friendly for altering than the "molded into the airbox" OEM ones.
At 773hp you're slightly higher than a Stage 2 tune level but still within the operating range of the OEM ones.
