Oil Leak?
5.0 V10 50v biturbo - 571 bhp
Biblijoy
Oil Leak?
Post by Biblijoy » Mon Jan 06, 2020 7:33 am
Hi I have recently received some trouble with my RS6.
Before driving a long distance I decided to pour in 500ml of oil, about 1000 miles in, my oil level sensor was showing as failing, but driving after 5 minutes it disappeared. Then oil level warning was flashing, I pulled over and rested the car for 5 minutes, checked it and the level was on the ‘o’ on the word ‘Do’.
Checking the engine oil level on a cold engine displayed 2 mm under the recommended level, could my seals be on the way out?
I have some images to show, one being cold engine, and the next being after the oil level warning shows on the dash board.
Biblijoy
Re: Oil Leak?
Post by Biblijoy » Mon Jan 06, 2020 7:36 am
After warning shows up
Cold engine
The check oil level comes on randomly, once cruising at 70.
Jim Haseltine
Re: Oil Leak?
Post by Jim Haseltine » Mon Jan 06, 2020 11:03 am
The level sensors are not the most reliable of devices. Mine would warn me, I'd check and top up the oil then I'd get another warning a couple of days later even though the level was fine.
c3nturi0n
Re: Oil Leak?
Post by c3nturi0n » Mon Jan 06, 2020 1:13 pm
as per Jim's... and i'd add - try and replace your oil level sensor every 3-5 years (not the easiest of jobs though).
2008 RS6 Avant (Monza Silver)
- H&R ARBs
IanH755
Re: Oil Leak?
Post by IanH755 » Tue Jan 07, 2020 1:42 am
Just to add, as this is NOT a wet sump car (unlike 95% of other cars) the way you check the oil is different. For a dry sump system like the RS6 you have to have a hot engine and you check the oil within a minute of shutting the engine off.
If you check it cold it WILL show lower than the actual contents are. All this is covered in the owners manual so have a read first just to prevent any over-filling!
Biblijoy
Re: Oil Leak?
Post by Biblijoy » Tue Jan 07, 2020 8:33 am
Thank you for the instruction, my manual is in Italian as it is an import haha
AreckiRS6
Re: Oil Leak?
Post by AreckiRS6 » Wed Jan 15, 2020 12:14 pm
When i bought my RS6 thats exactly how i checked my oil level and decided to top it up. Then after reading the manual i checked the oil properly on operational temperature and it was almost on maximum... I think manual is showing 100 degrees temp. let it idle for two minutes , switch engine off and after another 2 minutes check the oil level.
scoobysgone
Re: Oil Leak?
Post by scoobysgone » Thu Aug 13, 2020 4:58 pm
I have just had my oil leak fixed by Unit20 in Neston, it was a 200mile drive and they also found a suspension leak and replaced my faulty oil level sensor. I recently spent over £2500 at a main dealer to sort my suspension knocks at the front end, replaced every bush and it still knocked. Apparently a small pipe in the rear wheel arch was leaking and the suspension had lost pressure. These guys did the lot and without removing the lump. 2 1/2 days and she drives so much better. Cannot think of anywhere I would rather go. Brilliant Call Martin on 01513366888 if they can't fix it, scrap it. Mine is the 2008 C6 V10.
cammmy
Re: Oil Leak?
Post by cammmy » Fri Aug 14, 2020 11:33 am
Can I ask what they charged for the oil leak (assuming it's "the" leak)?
