Finally decided to go for it and do a manual swap!
A little bit of history...I’ve owned the rs6 since around late 2014 and enjoyed owning it very much. Every since buying it always been keen to do a manual swap and this is what she looked like when I first got her...
Being on the spanners as a mechanic it didn’t stay standard for very long, within a few months I had an exhaust built completely straight through no silencers or underfloor cats but opted to have them on flanged so they can be reinstalled. Shortly after that my better half bought me some kw coil overs and still being in my early 20s it had to be Low
Not long after this invested into some wheels and at the time a set of Porsche lobsterclaws came up at a good price so put them got bored quite quickly, made the car drive terrible!
Then just continued to just actually use it daily up untill the last 6 months where a change of job means I’ve now got a works van and no longer needed to use it everyday...
Here’s some photos of it actually being used
Loads of other stuff happened but on to the 6speed swap
So about 3 years ago I managed to pick up a donar car for a steal. Car I managed to bag was a 2.5tdi quattro a6, the reason for this is from what I’ve read the 2.5tdi boxes have the longest 6th gear. Here she is when I first picked her up with MOT for £260
Now with this swap I’ve sort of just been doing it in my lunch breaks and Saturday mornings and I haven’t managed to take that many photos but I will do my very best to fill in any gaps or if anyone wants so see anything more in-depth.
So the Saturday morning 21st dec I removed the engine and gearbox from the rs, not my first time!
With in about 3 hours... she was out
Then got annoyed with faffing on the floor so I decided to get involved with the forklift
That’s a far as I got up as a couple hours were chewed up by taking the recovery lorry to go pick up the donor car from a friends farm and bringing it back to work.
I’m my lunch breaks I got the turbo and manifold removed from the drivers side of the engine to remove to auto box.
I also removed the Sai system as the pump hasn’t worked for ages.
The following weekend I got to donor in and removed the following:
-gearbox with linkage and slave
-both front drove shafts
-propshaft
Photo you can see the flywheel and clutch:
Ttv flywheel and rs4 clutch kit, the clutch kit I’ll be swapping out to a ringer racing stage 4+ kit once I’ve got everything working and I’m happy with everything.
Got my rocker covers back from the powder coasters and got my new plates through!
So hopefully the 4.2 s6 starter will arrive with the correct size gearbox shim tomorrow so I can redrill and grind for the starter position.
List of things to do!
-jb weld intercoolers (new ones when I come back from newyork)
-starter mounting
-various gaskets and seals
-tensioner pads
-fit rocker covers
-gut down pipes
-remove pedal box from donor and slave line
-wire pin39 for clutch pedal switch
-wire reverse light switch
And loads more
Follow me on Instagram for day to day updates on my story
(Bowers_rs6)
Took a while to do this on my phone so sorry for the lack of grammar
