RS6 Timing belt replacement DIY
Re: RS6 Timing belt replacement DIY
Post by Shoppinit » Fri Dec 27, 2019 12:46 pm
That's why I think there is some confusion.
Banana man
Post by Banana man » Fri Dec 27, 2019 12:58 pm
This thread reminds me of this. :lol:
Post by Shoppinit » Fri Dec 27, 2019 1:21 pm
Hehe. Brilliant.
Classik
Post by Classik » Fri Dec 27, 2019 2:13 pm
Haha, yes that's a good one! :D
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Mɐʇʇ
Post by Mɐʇʇ » Fri Dec 27, 2019 10:33 pm
There is so much sense in this post.
IchBautAuto wrote:
Fri Dec 27, 2019 10:57 am
It might be reasonable to say that someone who does this every day for a living can get it within 12 degrees. That is "OK" but not optimal. I have 4 Audi, an A4, 2 x 2.7tt and a V8 and that's all the timing belts I do, so an average of 1 per year using 3 different techniques. I wouldn't even consider doing it without a crank pin and the cam bar, albeit I reckon I might be able to get a running tune without. Fact is that when the pins are in, the marks don't usually line up so using the marks instantly introduces an error.
My guess is that you have a confident mechanic who has a less than OCD attitude to accuracy. You wouldn't employ him in a race garage if you wanted to win, would you. That said, if you didn't have access to VCDS or whatever, you wouldn't even know if he did a great job or not. For the average Joe, if the car runs evenly with no fault lights its all good. We are in part a hostage to our own enthusiasm.
Classik
Post by Classik » Sat Dec 28, 2019 2:41 pm
I don't mind playing the fool, particularly if I learn something along the way. Could a bright mind clearly explain the different measuring blocks (those related to timings of course) as shown in VCDS:https://www.ross-tech.com/vag-com/m_blocks/090-098.html. I'd like to get a deeper understanding of what's going on other than just checking a number and verify it's within specs.
In particular a reminder of the target values for our cars and which mechanical part is involved when the readings are not within tolerance would be great!
Post by Shoppinit » Sat Dec 28, 2019 3:10 pm
Seems like a simple question, but the answer is not simple.
Have a look at this:
viewtopic.php?f=2&t=104670
Post by Shoppinit » Sat Dec 28, 2019 5:07 pm
So the tl;dr version is that group 93 gives you the inlet cam timing relative to the crank (when not dephasing). The acceptable range is +/- 6 degrees. Zero is best, obvs.
Assuming no problem with your dephasers and assuming the chain is installed correctly, if the readings are not within spec then the exhaust cam positions are not set properly wrt the crank. This is because the inlet cams are slaved to the exhaust cams via the chain. When the dephaser isn't dephasing, they should be in sync. i.e. zero degrees difference between them (group 91 and 92 values)
There are no sensors on the exhaust cams, this is another reason why it's so important to make sure the timing is set according to procedure. There's no practical way of measuring the exhaust cam timing.
Classik
Post by Classik » Sat Dec 28, 2019 6:40 pm
Very informative, thanks! I still need to educate myself on the subject, but I start to see some light..
Following up on your latest post, and supposing the dephasers/chains have been properly installed, how do you make sure the exhaust cams are properly aligned ? I'm probably mixing things up, but where does the bar come into play?
Post by Shoppinit » Sat Dec 28, 2019 6:43 pm
The bar locks the 2 exhaust cams in the correct position. With the crank locked at TDC you then you know the exhaust cams are timed correctly wrt crank.
Post by Shoppinit » Sat Dec 28, 2019 6:53 pm
Classik
Post by Classik » Sat Dec 28, 2019 8:15 pm
Still need to digest the information, but I'll get round this soon ;)
IchBautAuto
Post by IchBautAuto » Sun Dec 29, 2019 10:14 am
At the risk of being a pest, could I suggest that the statement above be taken with some additional detail added. The detail actually exists within the greater post but that sentence on it's own may mislead.
The crankshaft pin locks the crank in the necessary position. The timing belt drives the camshafts via two toothed belt pulley's. The pulleys are positioned on the camshaft via a taper so they are infinitely adjustable. The quote above is only true if the crank lock pin is in, the cam mark and the camshaft cap / head mark are aligned and the toothed belt is tight.
Post by Shoppinit » Sun Dec 29, 2019 11:41 am
I disagree. The cams have 2 flats on them to allow the precise positioning of the the thrust washer that the locking bar pins fit into. This means that if the cam locking bar is on then the cams are in the correct position.
IchBautAuto
Post by IchBautAuto » Sun Dec 29, 2019 8:45 pm
Correct. I do this infrequently and looking at the parts drawings it showed a round hole. No doubt for simplicity!!
Users browsing this forum: No registered users and 166 guests
