Gearbox Teardown & Refurbish - 6HP28A61
Re: Gearbox Teardown & Refurbish - 6HP28A61
The old gals coming up to 72K now and still running strong, (touch wood) this refurb has stood the test of time, another 5K and it will be time for a fluid change.
I really should get round to finishing the commentary on those last images and posting a parts list/costing, if only I could find the time.....
welwynnick
This is a really great thread. To the OP - did you find the cause of the original problem (stuck in fifth) when you were stripping and rebuilding?
Second - the title says your box is a 6HP28A61. I thought the C6 RS6 had the 6HP26A61. That's quite a big change. The second generation 6HP boxes had quicker changes and slightly more torque capacity.
This got me wondering if the 6HP28A61 was an improvement late in the model cycle, and something worth looking out for? What model year was your car?
Do you know if your torque converter or TCU were any different to other RS6 units?
Thanks, Nick
PS. For those that don't know, the 26 and the 28 refer to the input shaft diameter in mm, and the input shaft is one of the weak links in the 6HP26A61 (plus I got the impression that changes weren't that quick). "Weak link" is being a bit unfair, as the stock box seems to cope with tuning pretty well.
Thanks, Nick
For those really observant there is an image in one of these posts (third in this link viewtopic.php?f=47&t=129779#p894614 ) that shows the ZF tag with model and serial number stamped - This is on the underside of the box and tells you what the code is. Check yours and advise if its diifferent. I believe all C6 RS6 are 6HP28's but Im sure someone will correct me if this is not the case. Mine is a 2008.welwynnick wrote: ↑Fri Jun 14, 2019 2:38 pm- did you find the cause of the original problem (stuck in fifth) when you were stripping and rebuilding?
I put my sticking gear down to one of 2 (or both) main problems found; loss of pressure at the valve body seals (compressed rubber tubes) and bad clutch stack clearances.
slightly topic related... is there an indicator or oil level stick like on ZF's to determine the amount / level of oil in them?
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
No means of visually checking box level; you have to follow the procedure which is remove the filler plug run the car to get the box to temp (as seen in VCDS) and top up till it spills over the edge of the filler plug. Clearly the car has to be LEVEL.
Top of my head I cant recall the temp limits for this check but 36-38 rings a bell. I can check ELSA if you need it
cheers AT... that'd be great if you could please.ATinOf wrote: ↑Mon Jun 17, 2019 10:55 pmNo means of visually checking box level; you have to follow the procedure which is remove the filler plug run the car to get the box to temp (as seen in VCDS) and top up till it spills over the edge of the filler plug. Clearly the car has to be LEVEL.
- H&R ARBs
- H&R ARBs
Thank IanH for the OP - one of these.....
viewtopic.php?f=47&t=119322&p=784972&hi ... ox#p784972
level is correct with spillage from filler plug at 35-40 temp;
welwynnick
ATinOf, thanks for all your input.ATinOf wrote: ↑Mon Jun 17, 2019 10:24 pmFor those really observant there is an image in one of these posts (third in this link viewtopic.php?f=47&t=129779#p894614 ) that shows the ZF tag with model and serial number stamped - This is on the underside of the box and tells you what the code is. Check yours and advise if its diifferent. I believe all C6 RS6 are 6HP28's but Im sure someone will correct me if this is not the case. Mine is a 2008.welwynnick wrote: ↑Fri Jun 14, 2019 2:38 pm- did you find the cause of the original problem (stuck in fifth) when you were stripping and rebuilding?
He (welwynnick) doesn't own a C6 RS6, just endlessly talks sh1te about them.ATinOf wrote: ↑Mon Jun 17, 2019 10:24 pmFor those really observant there is an image in one of these posts (third in this link viewtopic.php?f=47&t=129779#p894614 ) that shows the ZF tag with model and serial number stamped - This is on the underside of the box and tells you what the code is. Check yours and advise if its diifferent. I believe all C6 RS6 are 6HP28's but Im sure someone will correct me if this is not the case. Mine is a 2008.welwynnick wrote: ↑Fri Jun 14, 2019 2:38 pm- did you find the cause of the original problem (stuck in fifth) when you were stripping and rebuilding?
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
welwynnick
Great thread! Only problem now is that photos are no longer visible
I noticed clicking sound turning the wheels while parking or when I get of the throttle at slow speed. I managed to recreate this sound on the lifter. You can see (hear) it in this video (it actually doesn't sound this loud in real life):
I went to audi garage and they told me it's prop shaft but I'm not that convinced. Clicking/knocking sound is coming from the box just before prop shaft starts - connects.
ATinOf would probably know right away what could be the cause (is it in the gearbox or prop shaft or something else maybe
Jim Haseltine
As I found to my cost about 18 months back, the front drive shaft inner cv joints have an amazing amount of free play even when new. Before I pulled the RH joint apart to replace it I expected it to be full of the usual black grease, especially as that was what was supplied in the new joint kit but no, when I took the cv boot off what ran out was watery brown oily stuff. The new joint stuffed full of the black grease had similar play to the old one but was a bit quieter when turning it manually.
Turned out the noise I was chasing wasn't mechanical, it was from a well camouflaged nail in a tyre.
That sounds just like the noise I got from my prop, get it up on the lift and with a hand on the prop rotate it back and forth, the cables or whatever it is inside the propshaft had broken, the longer you leave it the noisier it'll getzex wrote: ↑Thu Dec 26, 2019 10:39 amGreat thread! Only problem now is that photos are no longer visible![]()
ATinOf would probably know right away what could be the cause (is it in the gearbox or prop shaft or something else maybe).
I replaced my prop with one from bailey Morris as suggested by another member here and the supplied part was identical to the Audi one but around a third of the price of one through TPS
Mine was only noisy at low speed and turning, it had the carrier bearing replaced so definitely wasn't that
I found new prop shaft for around 800 eur. How much was yours?
Users browsing this forum: Google Adsense [Bot] and 85 guests
