Arm rest
Jbomb
Arm rest
Post by Jbomb » Thu Dec 19, 2019 8:06 pm
I have tried to find the answer to this but no luck.
Do you guys know if you can remove the arm rest leather piece without dismantling the entire arm rest?
dasquade
Re: Arm rest
Post by dasquade » Thu Dec 19, 2019 10:10 pm
Depends what you mean with dismantling the entire arm rest....no way around it without removing the airco pieces on the back and then the armrest is fixed with 2 bolts.
Jbomb
Re: Arm rest
Post by Jbomb » Fri Dec 20, 2019 9:29 am
Thanks for the reply.
It was specifically this part I wanted to remove so I could have it re trimmed.
dasquade
Re: Arm rest
Post by dasquade » Fri Dec 20, 2019 10:58 am
Yes that one. You might be able to pull it off with several trim removal tools, carefully working your way around it releasing all taps.
If not, taking the armrest off isn't that hard. Here is a good DIY guide...
https://www.audizine.com/forum/showthre ... Audi-A7-C7
Jbomb
Re: Arm rest
Post by Jbomb » Fri Dec 20, 2019 11:22 am
Thank you 😊
